Previous in Forum: Pump Foundation on Grid Floor   Next in Forum: Buckling Calculation of Cone Storage Tank
22 comments
30' Scrap Trailer From Scrap!
11/14/2010 1:36 PM
Although many people here work with all new materials and often times repetitive concepts I rarely do so I thought that once again I would enlighten the engineering world with a bit of my hillbilly/redneck engineering and fabrication skills by showing off another of my custom built 'farmer Fred engineering creations'.
This time it's a 101" by 30' flatbed trailer I built for a friend of mine out of salvaged metal from scrapped out items he had on his family farm. He needed a good heavy trailer to haul scrap metal with so I figured that the best thing to do was build it out of the assorted scrap metals that he already had.
What I started out with was a old and rather bent up mid 1970's 14' x 70' trailer house frame he had parked out in the trees for the last few years and what was left of the back of an old semi trailer floor.
Basically what I did was strip the trailer house frame down to two I beams and cut the bent section out to form a solid 30 foot flatbed frame. The shortened frame still had a little twist to it so I took the two bent sections and plated them in beside the main frame but with the bends going the opposite direction. This in effect worked to cancel out the bends for each I beam and produced a surprisingly strait frame to work with.
For the cross beams I recycled 14 3" x 4" I beams from what was left of an old semi trailer floor and cut them to fit in between the two trailer house frame rails that way the top of the deck is level with the top of the main frame itself.
It presently rides on three 6000 # rated axles with two of them equipped with electric brakes. Eventually it may get them replaced with a pair of 10,000 # axles. The current three axle setup is set with the front axle on a 16/14 split, the center of the front axle is set back one foot from the center of the deck, to give it a good balance but still allow for sufficient tongue weight in order to make it travel smooth and handle well when loaded.
The original trailer house tongue was only three feet long so I cut it off and replaced it with a 6 foot tongue to make turning sharper possible and to greatly improve the ride and stability of the trailer when loaded. The only new materials used was 40 pounds of 7018 welding rods, the new treated wood for the deck, the 440 decking screws required to fasten it down, the new adjustable hitch, and the new heavy duty jack.
Eventually it will also get removable 16" side rails and lighting but for now that is up to my friend to do when he gets more of the parts in. Not a bad trailer for under $1500 total invested plus it rides very light and smooth despite weighing 5000 #'s and being 36 feet long from tip to tail!
Re: 30' scrap trailer from scrap!
11/14/2010 2:01 PM
Well, it ain't too purty, but it looks hell for stout. Nice job.
I was raised on the farm, too and it's amazing what you can do if you have no money and only go to town once a week, if that.
My wife's amused by some of the things I make around the house when Home Depot is less than a mile away. We're city dwellers now, mostly.
I salute your "hillbilly/redneck engineering and fabrication skills".
Re: 30' Scrap Trailer From Scrap!
11/14/2010 2:57 PM
Nice one, it's great to recycle stuff.
(Isn't it a bit over engineered to carry your lunch pail?)
11/14/2010 5:02 PM
The rough estimates on the capable stress loads it can take are around 40,000 # distributed which is more than double the axles capacity and over three times what a 3/4 ton pickup is rated to legally pull.
I built it to be solid and very durable. The people who will use it are less than gentle with their equipment. (Those 'in too big of hurry to pay attention and do it right the first time' types.)
The local running joke/bet with their friends and neighbors is for how long it will be before they wipe out someones vehicle because of its length and rear end turning swing or how long it will be before they bend the axles to the point of destruction from overloading it.
11/15/2010 11:02 AM
My only concern is with mobile home brakes. They are not designed for long life. Mobile home are famous, or infamous if you ever move them much(Which I did for a couple of years in my youth). They are usually not repairable and never reliable. On any given day they range from barely being able to tell if they are working to skidding all 4 wheels. I strongly urge your friend to get some kind of better brakes as soon as he can. Also be careful of concentrated loads. A 'friend' of mine borrowed my 24 foot (plus tongue) 2 axle that is similar to yours. He load a very heavy pontoon boat on it by blocking it up on the ends and put a nice kink in the frame because of no center support going down rough country roads. One thing I like about my big trailer is it is too much trailer for most of my friends, as opposed to my 8 footer that I some times have to call around to find it when I need it! -- JHF
11/15/2010 12:11 PM
He lives in the north east part of the state and for the most part what I have seen of many trailer house brake systems is that many are just like any other electric brake system. For the heavier loads the adjustable hitch can be switched out with a pintel ring so that they can pull it behind their semi which has more than enough brakes to handle the trailer when loaded down. But yes I wont be the least bit surprised if he slides himself through an intersection while pulling it with their pickup once or twice!
As far as longevity is concerned with trailer house axles the most common trick to making them last is replacing the crappy plastic hub seals with good ones so the grease stays in and the dirt stays out then of course replacing the cheap ancient grease they used with new good quality axle grease.
I did design the frame so that eventually the three 6000 # axles can be replaced with a pair of 10,000 # units. Right now the trailer axles will have to do until he gets enough scrap hauled in and some money built up.
As far as bending the frame is concerned the axles and springs will collapse before the double frame bends or gives out!
Good Answers: 58
11/14/2010 5:55 PM
tcmtech,
Nice job!
I have always been surprised at the resurrections that have taken place from remnants that have been setting on the back forty for 20 years.
It is amazing what you can do with an oxy/acetylene torch and a welding machine!
Again, nice job!
11/14/2010 8:14 PM
Very impressive!
Would you be willing to explain to my wife, why it is that I don't throw stuff away?
She calls me a hoarder, (I can't throw away a straight nail or a good screw).
Then again.....she might be right, whenever I need something, I can't find it, it's buried...............I go to Home Depot and buy slightly more than I need, just in case.
Good Answers: 123
11/14/2010 9:09 PM
Nice one. A coat of paint, and it becomes a $6,000 asset.
Bob
11/14/2010 11:32 PM
Cool!
I recently built a tow bar for my microcar prototype out of an old bed frame.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
11/15/2010 10:47 AM
Nice job, very creative.
I was wondering about how the 3 x 4 I-beams were welded to the main frame I-beams. Were only the top & btm flanges welded, or that plus an inch in the center of the web, or welded all around, or?
Any detail pics available?
What type of welder was used? Stick or buzz box arc welder? Acelylene? Mig or Tig?
11/15/2010 11:56 AM
I did them with a top and down the web weld. The welding was all stick done with a Miller Shop master 300. The cutting was all done with a Thermal dynamics 102 series plasma cutter.
Sorry I don't have any up close pics. My friend lives 210 miles away in the north east corner of the state and I am home now.
Good Answers: 196
11/15/2010 1:57 PM
tcmtech -- Long as you're into "How I built it" .........
How did you move and lift the pieces? Even a 3x4x8ft I-beam is a pretty heavy lift for one guy. Do you have a tractor with a bucket on front you can use like a crane? Or maybe one of those little hydraulic utility cranes mounted on your truck?
Also what measuring methods did you use to level and square it up? Same as building a wood frame structure?...........Ed Weldon
11/15/2010 3:29 PM
the 3" x4" I beams only weigh about 40 pounds so they are easy to move by hand. The rest was done with the pay loaders. By lifting the heavy pieces near their center of gravity its very easy to move and align them by hand before welding in place.
As far as squaring it up that is just basic geometry and math. Once several primary reference points are chosen the rest is just a matter of measuring and welding.
A good calculator, tape measure, some string and clamps are all thats required to build a good trailer!
Good Answers: 19
11/15/2010 10:56 AM
I'm impressed. I might have to get a small torch and 120 VAC "buzz" box to attack some small pieces of scrap steel in my garage!
How many hours of labor did you put into this project. 40# of welding rod suggests more than a couple of hours of time. Still, a project like this probably kept you out of the pool hall and gave a sense of accomplishment when finished!
Good Answers: 196
11/15/2010 11:25 AM
tcmtech's story makes me tired just reading it.
Far as the brakes are concerned we need to remember that those guys are in North Dakota where their hills look like the potholes in California highways and they can see any reason to stop from two miles off.
Gonna go take a nap now............ Ed Weldon
Good Answers: 19
11/15/2010 11:31 AM
Far eastern ND might be like that, but south or Minot can get a bit hilly, and the local gravel roads will jar your teeth when they do dry out in the spring.
I have been there, and grew up near Luverne ND many years ago.
-----------------\___________ SKI North Dakota!
11/15/2010 11:59 AM
Between my friend and I we had around 100 hours combined labor. We knocked the whole thing out in six days from junk trailer house frame to the rolling trailer as seen in the pictures.
Good Answers: 123
11/15/2010 12:04 PM
The first thing I ever welded with was a 110 Buzz Box that was plugged into a 220 outlet. I wish I had been a little smarter then. It scares me now.
Bob
11/15/2010 1:45 PM
don't spend money on ac welder, save a few more months and buy a good used ac/dc welder, the quality of the weld is so much better when you have a dc stable current to weld with, I had once a snap-on ac buzz box and never was happy with it, spent big money on a tig/stick millermatic 230 and never looked back,
Mitch retired peugeot mech
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
Good Answers: 12
11/15/2010 12:26 PM
To me a Hillbilly/redneck design usually involves the cut off end of a pick up truck.
From what I can see, this is an astounding feat of fabrication that maximizes recycling. I have yet to meet a farmer that will part with much. Lucky for you, that leaves you with a treasure trove of materials to play with. Also lucky for him, for the end result.
Once completed, I hope that you give it an interesting colour scheme. That should not be to hard, if can toss that collection of paint cans that he has, and find the ones that have not dried out.
Please show the end result.
11/16/2010 6:35 AM
What a mysterious and wonderful world this one is....
11/19/2010 7:53 PM
good looking unit, wish i were out on the farm
Register to Reply 22 comments
Anonymous Poster (2); bob c (2); Ed Weldon (2); flyinghigh (1); hlb244 (1); Icarus (1); KJK/USA (1); kramarat (1); lyn (1); MoronicBumble (1); PWSlack (1); Ried (2); tcmtech (5); user-deleted-1105 (1)
