Previous in Forum: Fire Main Design Pressure   Next in Forum: Compressors
Accostic Fatique in Relief System Piping
11/16/2010 4:34 AM
How to eliminate the effect of acoustic fatique or vibration induced fatique in a relief system piping.
Re: Accostic Fatique in relief system piping
11/16/2010 4:48 AM
Please explain more. This might be a salient issue, but not yet very well known.
11/16/2010 6:25 AM
Eliminate the cause of the vibration.
Re: Accostic Fatique in Relief System Piping
11/16/2010 12:03 PM
Some standards are like the North Pole and some are like Mecca. People use both to get their sense of direction, however, only one is a preferred destination. - P.E. Scheibmeir
11/16/2010 7:48 PM
If relief piping is undersized, fluid velocity can exceed the speed of sound. This could set up standing waves and such phenomena that might make for sonic-frequency vibrations, leading to early fatigue (note the g, not q) from the rapid accumulation of cycles. (This is a bit of a guess, suggested by "acoustic", but it may be what we're talking about.) Solution: larger piping. There was an ASHRAE (American Society of Heating, Refrigeration, and Air-conditioning Engineers) code revision in 1994 about this.
Good Answers: 67
11/17/2010 12:22 AM
Acoustic fatique or vibration induced fatique are two different things. Acoustic fatique may be for the people working nearby and vibration induced fatigue is for the life of the relief system piping.
Acoustic fatique can be tackled by providing noise abatement measures in relief system piping. This can be done in following ways depending on severity of the noice:
1. Put a sound barrier (intall noice hoods).
2. Provide a silencer in relief system piping. It can reactive type or absorptive type or a combination of both depending on severity of the noice.
3. Provide mineral wool insulation of the piping.
It is advisable to check the noise level. Normally acceptable norm is 85 dB at one metre distance.
vibration induced fatigue can be tackled by providing appropriate piping support and reducing outlet velocity by increasing pipe size.
11/19/2010 3:53 AM
My concern is about the failure due to the vibration induced by sound in a relief piping system when the relief valve pop off
11/19/2010 3:56 AM
And how the D/t ratio, where D in inside dia and t is thickness of pipe, have an effect on acoustic fatigue. and what shall be the value for this.
Anonymous Poster (2); MrGeneRall (1); pritam (1); PWSlack (1); Tornado (2)
You might be interested in: Piping Services, Pressure Relief Valves, Piping Systems
