Previous in Forum: Accostic Fatique in Relief System Piping   Next in Forum: Bearings
Compressors
11/16/2010 12:16 PM
when the engine is constantly loaded to the maximum, and the life of compressor valves is short, then you reduce the lift on compressor valves. Would this help prolong the life of the valves? If so how? Or will it bring another problem if so what problem?
Good Answers: 141
Re: Compressors
11/16/2010 8:06 PM
Best way is to have a one direction valve between the compressor and the tank with a relief to atmosphere through the regulator on/off controller. The engine starts at no pressure in the feed line this way.
Plenty of room here
Re: Compressors
11/16/2010 8:56 PM
Is this by any chance a refrigeration compressor, which might be receiving floodback? If so, the problem might not be the heavy loading, but rather the thermal shock of cold liquid striking the valves.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Compressors
11/16/2010 11:38 PM
Clarify and explain to us what you are working on.
Speak softly and carry a big stick.
Register to Reply 3 comments
dvmdsc (1); standarded (1); Tornado (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
