Previous in Forum: instrument   Next in Forum: Coplanar and In Line type PT
Instrument
11/24/2010 4:45 PM
How Change of Gland VALVE Packing
Re: instrument
11/24/2010 5:00 PM
Take out old, install new.
Re: instrument
11/24/2010 5:43 PM
The may depend on specific valve construction and on the characteristics of the fluid involved, especially toxicity.
Most refrigerant valves, for instance, are back-seating, which means that when fully open, the valve packing (or seal) is isolated from the fluid. Thus you can unscrew the packing nut, remove the old packing, install new, and retighten the nut.
In general, you need to know what is isolated from what (inlet, outlet, stem area)when the valve is either open or closed.
Re: instrument
11/24/2010 7:50 PM
Sigh. If you have to ask, you're not qualified to do this repair. Call a plumber. You may have to do this anyway because you may have to replace the whole valve due to a lack of replacement parts or a to badly damaged valve.
Re: Instrument
11/29/2010 1:02 PM
If all else fails, read the instructions.
Register to Reply 4 comments
kramarat (1); PWSlack (1); redfred (1); Tornado (1)
