Previous in Forum: High & Low Tap Point in Tank   Next in Forum: Instrument
instrument
11/24/2010 4:41 PM
Change of Gland Packing i want the proceduer
Re: instrument
11/24/2010 5:10 PM
Contact the valve manufacturer and ask them.
Can you Google?
Or, do as kramarat says. Out with the old, in with the new.
Re: instrument
11/25/2010 12:35 AM
I concur. Our gland repacking team often recites the acronymic mantra: OWO IWN.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
Good Answers: 12
Re: instrument
11/25/2010 8:04 AM
Unless you are dealing with a very large valve, meaning replacement is prohibitive. Just change it. If the packing has failed due to age, the rest of the valve can not be far behind.
If it is a large valve that has to be repaired in place, why are you not talking to the manufacturer?
Re: instrument
11/25/2010 2:27 PM
far too much information i dont know where to begin
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
Re: instrument
11/25/2010 9:25 PM
Somewhere in your "too much information" you already have the answer - just requires a little bit of your effort.
The problem we have is that we don't have any information about your problem - so it is difficult to give an answer. We can give some suggestions.
Is the gland in a
pump ?
valve ?
bearing/bushing ?
soft/hard/flexible ?
Have you done this sort of work before?
Re: instrument
11/27/2010 1:31 PM
proceduerr,begin.....tighten packing nuts until bottomed out------ then make system safe ----- isolate----- open---- remove; worn compressed beyond limit / worn -hardened non pliable.(dig out with a pick if thats how small it is).----replace :new end with-----tighten------ lube----- re tighten (until it seals) and still feels right.
klearzen
Re: instrument
11/29/2010 1:04 PM
Before that lot:
  • Isolate all sources of pressure, valve motive power and process fluid from the valve and raise Permit to Work.
Anonymous Poster (1); AussieBob (1); Icarus (1); klearzen (1); lyn (1); MoronicBumble (1); PWSlack (1)
