A friend of mine, who lives in the Canary Islands and so has never seen real snow, has some quite interesting idea.
It is hard to believe that millions of learned people all around the Planet have not considered this before.
A powerful snowfall would be of 6 cm to the hour or 60 mm to the hour. This makes one millimeter per minute.
In developed Countries it is hard to conceive a road with an ocupancy of less than one vehicle per Km.
If the vehicles run at a safe speed of 60 Km/h = One Km per minute, if we look at a determined point, one vehicle will pass every minute.
Now, if the vehicles, or a mojority of them wear snow plowers, they would have to sweep one millimeter of snow.
¡But this is riduculous! (You probably think)¡You cannor even see one mm of snow!
Exactly, this is why a trowaway simple snow plower would be more than sufficient.
If you think that in a bad snowstorm there would never be one vehicle per Kilometer, probably this is false; because people would not be scared trusting in such a miraculous new antisnow system.
The real problem is: How do you get the people to use these primitive snowplowers?.
By the Governments renting them for free, storing them at small storehouses, at the beginning of each (Prone to be affected) section of road?
Having them installed and recovered in seconds by Government Employees.
Or giving an incentive to drivers wanting to use them?
The simplified and effective snowplow has been already designed by my friend and me. It is very effective and it throws the small quantity of snowdust far away from the road surface.
Due to the efficiency of the system, there is no time for ice to form.
Although the problems with this "Invention" are mostly sociological, I cannot say that there would'nt be some technical problems, because, of course it has never been tested. And probably never will be.
Chorete
