Previous in Forum: Trying to Find Approx Age of Chair   Next in Forum: Domestic Water Heater in Main Water Supply
16 comments
Location: The only place where hell can really freeze over.....Michigan
Brake Screw?!?
12/03/2010 5:11 PM
Fellow CR4'ers, I am in need of your vast knowledge and experience.
I have a project that i am working on that uses a "spring loaded set screw" as a brake to apply force to a pivot shaft to reduce the amount of ease that a part rotates around an axis. My customer currently supplies these parts to us and he has requested that we find, or design, a cheaper version.
This component is a stainless steel "set screw" that has 2 belleville washers (springs) and a brass shoe. The brass shoe floats on a shaft from the set screw and the belleville washers (springs) apply pressure onto the brass shoe. So as you tighten the set screw the belleville washers increase in the amount of tension they are applying to the pivot shaft. This is all one piece, not separate pieces (i will try and get a picture posted on Monday).
Does anyone know of a part that meets this description that i could purchase rather than make it? Seems to me that someone who is tooled up to make this part would be able to produce it much more cost effective than i could
Thanks for you assistance
Re: Brake Screw?!?
12/03/2010 5:58 PM
Think little bit more,and you will find the solution your self.
Never get despaired,that's my experience and advice to you. No body understands better about what you are doing than you.
Re: Brake Screw?!?
12/03/2010 6:13 PM
This sounds like "ball plungers" or "spring plungers." I don't know the size of yours, but the rough average price is ~$5 each in Grainger.
Re: Brake Screw?!?
12/03/2010 6:22 PM
Why not do like the rest of the universe. Have one non-Belleville flat washer being pressed by two brass shoes pads.
Some concept of scale would be nice. Forces acting on the "driven" part to make it move. Washer diameter, you know, just enough information to allow us to help you.
Good Answers: 58
Re: Brake Screw?!?
12/03/2010 6:57 PM
I thought I saw somewhere a set screw with a plastic tip set into the end.
mike k
Good Answers: 58
Re: Brake Screw?!?
12/03/2010 7:26 PM
Here is one.
They have different types of plastic in the tips.
mike k
Re: Brake Screw?!?
12/03/2010 8:34 PM
Try using teflon instead of brass or
Use a totally dissimilar approach by using nylon / leather cord with single turn around the shaft tied to adjustable tension springs at the ends or
Follow the exerciser cycle arrangement where a screw adjustable stretch 'nylon strip' applies pressure to a large dia plastic wheel.
Most importantly as the worthy Guest has appropriately said "No body understands better about what you are doing than you".
Knowledge sharing is a WIN-WIN situation
Re: Brake Screw?!?
12/04/2010 10:45 PM
We would like to take a look at your component - we specialize in prototype/low volume as well as production - our 30+ yrs of experience in design/concept r and d would be a good fit with what you're looking for - please send print/material type/heat treat/plating specs to kjacobs@ptmcorporation.com - volume - we'd like to help you out or steer you in the right direction - thx
Best Regards and have a lovely day!
Re: Brake Screw?!?
12/04/2010 10:48 PM
Try to use the set screw and a piece of round polyurethane instead
Re: Brake Screw?!?
12/04/2010 10:50 PM
Use polyurethane as a spring and brake.
Re: Brake Screw?!?
12/04/2010 11:34 PM
are you thinking of Vlier pins? some call the ball plunger set screws, and such.
Vlier is mfgr name.
Re: Brake Screw?!?
12/05/2010 12:39 AM
we are all farting in the wind thinking of things. we need the facts. at first it sounded to me the same set up an electric motor has for the brushes. brush , spring ,screw. than on a larger scale a hydraulic roller lifter came to mind. How much was your customer paying for the part. If the customer wants a cheaper version send a proto to china.you get what you pay for.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
Re: Brake Screw?!?
12/05/2010 2:27 AM
Be patriotic! Order it from China or India! you would support Bush and Clinton partriotic families!
Re: Brake Screw?!?
12/05/2010 8:21 AM
Post the picture with the part next to a ruler so that we can see the siz roughly.
Also post a picture with it taken apart, also next to a ruler....
Re: Brake Screw?!?
12/05/2010 8:34 AM
"a brake to apply force to a pivot shaft to reduce the amount of ease that a part rotates around an axis. "
Avail suitable/required space around the pivot and have a polymer (Nylon like) bush with good resilience (not rigid) with an interference fit. This would constantly apply break on the shaft and would prevent free rotation.
Location: DeBary, Florida USA (Central Florida area - Orlando)
Re: Brake Screw?!?
12/05/2010 8:53 AM
Need dimensions. Pictures and/or drawing will help. What material is the "brake" applied against? Joe
Think Professional Services are Expensive? Try Amateurs.
Re: Brake Screw?!?
12/05/2010 8:46 PM
As I understand it, the set screw pushes on the Belleville washers, and they push on the shoe to apply some braking force to the shaft.
Would something like a worm drive hose clamp with a suitable lining do the trick?
Lehman57
Register to Reply 16 comments
Andy Germany (1); Anonymous Poster (5); darren2264 (1); Joe Moleski (1); KrisJacobs (1); Lehman57 (1); lyn (1); mike k (2); mountk2 (1); Tornado (1); yesyen (1)
