Previous in Forum: Inverter Duty vs Conventional AC Induction Motors   Next in Forum: Problem with Earth Leakage
11 comments
XLPE Cleaning
12/06/2010 2:14 AM
What is the liquid used to clean the cores of an XLPE cable when doing terminations ?
Pathfinder Tags: XLPE
Re: XLPE
12/06/2010 2:35 AM
1. Saliva
2. Snot
3. Use your imagination
4. Solder acid flux, followed by rinse
5. Orange/lemon/lime/grapefruit juice
6. Other?
Re: XLPE
12/06/2010 3:12 AM
7. Or none of the above...
Im trying to remove the carbon black semi conductor skin off the core insulation..Safely.
Ive been told to use peroxide, I need to confirm this.
Re: XLPE
12/06/2010 3:52 AM
I apologize (but not much) for being facetious. Just what solvent might help I'm not sure. Some things like peroxide or acetone or (who knows what) might work, which could turn into a research project. The insulation you might want to remove (PVC, PE variant, etc.) probably has an associated solvent; again a research inquiry.
Re: XLPE
12/06/2010 1:24 PM
Carbon is practically insoluble in any common solvent, however, a cloth moistened with any non-conductive fluid may succeed in wiping the carbon black off. The problem then becomes the non-conductive fluid: most are flammable, and many are carcinogenic. So the CoSHH assessment comes next.
Re: XLPE
12/06/2010 3:54 AM
Urine. But I never seen anybody cleaning cable cores.
Register to Reply Off Topic (Score 10)
Re: XLPE
12/06/2010 4:03 PM
CR4 ADMIN: Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Re: XLPE
12/08/2010 12:55 PM
Good Answers: 131
Re: XLPE Cleaning
12/06/2010 1:11 PM
manufacturers of cable splice and termination kits don't generally tell what they provide for cleaning up the semicon or other parts of the cable in their instructions. For example, 3M recommends appropriate abrasive (sandpaper) or non-flammable cable cleaning solvent in their splice kit instructions:
American Polywater sells cable cleaning kits that have pre-packaged wipes that have appropriate solvents for cable cleaning:
For general cleaning of electrical apparatus of many sorts, we have had good results with isopropyl alcohol (tech grade - 99+%). It evaporates fast, leaves no residue, and does not attack most insulating materials. However, I can't speak sprcifically to its use for your application.
Re: XLPE Cleaning
12/07/2010 5:30 AM
which voltage u are telling hv or lv
Re: XLPE Cleaning
12/08/2010 12:53 PM
elv.
Re: XLPE Cleaning
12/11/2010 5:31 AM
CTC
Register to Reply 11 comments
Anonymous Poster (6); Borrowdale Dan (1); PeterT (1); PWSlack (1); Tornado (2)
You might be interested in: Cores and Tubes, IP Cores, Magnetic Cores
