Previous in Forum: Car Mechanic Training Videos   Next in Forum: Videos for Training About the Modern Car
2005 Hyundai Tucson Alignment Question
12/11/2010 2:12 PM
Should my 4wd 2005 Tucson need a rear end alignment, or am I being misled?
Re: 2005 Hyundai Tucson Alignment Question
12/11/2010 2:39 PM
Cars with an independent rear suspension need a four-wheel alignment, simply because the rear tire alignment isn't fixed and can go off course, just as the front tires can fall out of alignment.
Whether you get a four-wheel or front-wheel alignment for a car with a solid rear axle depends on your willingness to spend the money; your mechanic's procedure, as many offer only four-wheel alignments; and if there are suspicions that there might be a problem with the rear axle alignment.
The first law of thermodynamics is you do NOT talk about thermodynamics.
12/11/2010 2:52 PM
I agree with Mizuti. Have you noticed any unusual tire wear?
12/13/2010 10:25 AM
Thanks for explaining when/why a rear alignment is necessary. My car does have the ind. suspension, so I guess the guy was being honest.
Good Answers: 60
12/12/2010 7:33 AM
Why are you asking ? do you have any problems ? ie tire wear on rear tyres vehicle steering strangely what makes you think you need alignment ?
12/13/2010 10:27 AM
Car was definitely pulling to the right, so when I had it evaluated, the guy said I needed all four done. After the fact, friends had me wonderig why the rear would need it, but I see an explanation above. Thanks!
Mizuti (1); peterg7lyq (1); Psalm19 (2); Usbport (1)
