Previous in Forum: Moment Coefficient at ACI Code   Next in Forum: Steel Structure, Ceiling Cracks
14 comments
SHOPDRAWING
12/11/2010 3:19 PM
I HAVE A PROJECT(BUILDING) AROUND 3000 SM & 11000CM OF CONCRETE.
OUR SCOPE OF WORK ONLY UNTILL SLAB ON GRADE.
IF YOU TELL ME ABOUT ANY WEBSITE TO DO SHOPDRAWING FOR THIS BUILDING I WILL APPRETIATE.
Re: SHOPDRAWING
12/11/2010 3:47 PM
THAT'S JUST AMAZING! 11,000 M3 ÷ 3000 M2 ≈ 3.67 M AVERAGE SLAB THICKNESS! IS THIS A DAM PERHAPS? A SKETCH WOULD HELP! SO WOULD COMIC SANSERIF FONT!
Re: SHOPDRAWING
12/11/2010 6:36 PM
Re: SHOPDRAWING
12/11/2010 9:47 PM
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: SHOPDRAWING
12/11/2010 11:34 PM
Read the website rules. Turn off the caps key.
Speak softly and carry a big stick.
Re: SHOPDRAWING
12/13/2010 10:27 PM
i like the bits of wisdom u post, but it would be nice if u would attribuate it 2 the author.
Good Answers: 50
Re: SHOPDRAWING
12/14/2010 12:11 AM
Generally I would, but since I know Tornado's engaging in witty and engaging banter with our OP, the implication is that the comment is directed to the OP. Thank you.
Re: SHOPDRAWING
12/14/2010 12:23 AM
Teddy Roosevelt.
Re: SHOPDRAWING
12/12/2010 12:17 AM
Drawing is one of the languages for engineers. Working drawings are prepared as per the calculated values based on engineering principles and standards. You can get the assistance from reputed consultants in your area to assist you for an immediate solution.
Do not follow where the path may lead. Go instead where there is no path and leave a trail." -- Ralph Waldo Emerson
Re: SHOPDRAWING
12/12/2010 3:47 AM
Please advise for what purpose you require the shop drawings? I suspect that they have been lost. My company can determine the rebar depth, diameter using a Ferroscan and whether there are any voids or porosity using a GPR. This info can then be used to create drawings of the Structure. Please contact me on my email andrew@macgregor.co.za if i can be of assistance. We have just completed a similiar sized project in Madagascar where the client wanted a detailed survey of his re-inforced concrete building to check that the cover was adequate to prevent corrosion and if the concrete strength was up to specification. We also recommended a detailed vibration analysis of the building to determine if there was the possibility of any structural weaknesses.
Good Answers: 50
Re: SHOPDRAWING
12/12/2010 11:03 AM
Read the website rules. No e-mail addresses in posts.
Re: SHOPDRAWING
12/12/2010 6:31 PM
Assuming that you are working from a set of drawings prepared by a competent engineer, you required shop drawing submittal would be the reinforcement and anchors which would normally be provided by your fabricator. Your design mix for the concrete would be provided by your concrete supplier or if you have an onsite batch plant, your testing lab. If this is a monolithic pour "back off cause 'you' ain't gonna make it"
Re: SHOPDRAWING
12/13/2010 12:33 AM
is there a general contractor in charge of the project? that's his job to supply u with drawings. are u bidding on this job? if u have to ask, it's way be-yon you expertice. do u need re-bar and expantion join info? see general contrator again.
There's no stupid questions, only stupid answers
Reply Score 1 for Off Topic
Re: SHOPDRAWING
12/13/2010 9:00 AM
If it is a shop drawing you should not be downloading it from the web!!! The design engineer should have provided you with approprate cross-sections (if you are the design engineer and you can not generate a shop drawing QUIT NOW)
Re: SHOPDRAWING
12/14/2010 6:56 PM
CR4 Admin:Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
andrewmacgregor (1); Anonymous Poster (2); CONWAYMECH (1); jlstitt2 (2); lyn (1); mrswamy (1); PWSlack (1); standarded (3); Tornado (2)
