Previous in Forum: Basic Information for Circuit Design   Next in Forum: How Do I Control the Torque on a Wind Turbine Generator
44 comments
Dishwasher Question
12/12/2010 9:14 AM
Dishwasher question: The dishes come out with a white coating and need to be washed by hand although the machine cycle (either one) is finished. This is the 2nd dishwaher with the same problem. Any suggestion? Thanks to all and best wishes for health and prosperity in this new year.
Re: Dishwasher question
12/12/2010 9:24 AM
This is probably caused by minerals in your water. It won't hurt you. Rewashing isn't necessary unless you just don't like the way they look.
One thing that may help, if you don't want to get involved with water treatment, is to turn off the dishwasher when it starts the dry cycle and let them drip dry. The dry cycle uses a heating element that evaporates the water faster, leaving a higher concentration of minerals.
12/13/2010 12:06 AM
Ensure that there is always dishwasher salt in the respective container. Ensure that the detergent has a rinse-aid included, if not you must keep the rinse aid container topped up (normally a liquid). It must also be said that some manufacture of glass unavoidably stains white. Generally once this occurs the stain is permanent.
Cheers
Peter
12/13/2010 12:41 AM
I had the same problem, refilling the salt sorted the problem.
12/13/2010 12:44 AM
I didn't get a second dishwash machine, I got married, but still ended up doing the heavy dishes.
12/12/2010 9:51 AM
Wash by your blessed hands or ask a trusted relative or friend to do that for you.
12/12/2010 11:11 AM
The second dishwasher with the same problem means it's soap(either too much or the wrong kind for your machine). Also forced drying is bad. It does drain properly, right?
Put a cup of vinegar in and run it through a rinse cycle. Add a tbl spoon of vinegar with each load. Not too much detergent.
Disregard post #2. He's obviously delusional.
12/12/2010 11:33 AM
That would be sad if the poor person is on their second dishwasher, only to find out they were putting in too much soap.
Good Answers: 181
12/12/2010 12:28 PM
Typical "hard water" problem, your kettle probably has scale built up on the element. Use a small amount of water softener in the soap compartment.
Or give the wife a clip around the ear and tell her to do the job properly!
I wonder why I'm divorced?
12/12/2010 12:38 PM
Divorce is allowed only in case of fornication ,not because of washing machine,why you did that error TonyS ?
12/12/2010 12:44 PM
OH, Jesus Christ, can't we leave religion out of this???
12/12/2010 12:48 PM
Could you say that nicely please. You're not being very sensitive.
12/12/2010 12:53 PM
I'm tired of being nice.
Good Answers: 181
12/12/2010 3:37 PM
You aren't nice, we wouldn't expect any different of you. Keep it up!
We should have a grumpy section, membership by invitation only.
12/12/2010 3:55 PM
I know that I will regret this forever. If you have a life, don't even start: Re: Bath Breaking Technique Read at your own risk. I never got hooked, like some of the weaker ones.
12/12/2010 4:13 PM
NOOooooooooooo
And while you're at it let's go down to the haunted house
12/12/2010 4:33 PM
You are a trouble maker.
12/12/2010 7:28 PM
Actually linlynch is not a trouble maker but the smart man 'Gizma' is, he uncovered you crystal clear.
12/12/2010 12:55 PM
Kramarat ,you are Pakistani background,do not get involved in something does not concern you.
12/12/2010 1:00 PM
Uncle Jimmy............................Is that you?
Good Answers: 74
12/15/2010 5:47 PM
It looks like you had your head in a dish washer while it was on. Or was it that you had your head in something else that you could not handle?
Hope they are supplying you with enough of that white powder
The Twain Has Met
12/15/2010 6:04 PM
Good Answers: 74
12/15/2010 6:11 PM
One strike out.
The Twain Has Met
12/15/2010 6:29 PM
Good Answers: 130
12/13/2010 1:09 AM
What?
What's religion got to do with it?
Both dishwashers I fornicated with, divorced me.
12/13/2010 10:22 AM
If she makes it all the way to the lounge while you're watching sport, to tell you that there's a problem with the dishwasher, then her chain's far too long.
Good Answers: 918
12/12/2010 12:48 PM
Well, you can safely eliminate the dishwasher. ;-)
As others have said, this is a water problem.
Common water spots, but at a larger magnitude. Do you have a water softener? What is your water source (well or city)?
It may be useful to have your water tested. The hardness of the water is most likely the problem (particularly with well water). That is, there are minerals dissolved in the water. Typically, you can add a water softener machine to the supply side of your water supply. Most use salt as a means to recharge a container of beads that strip out minerals from the water.
Note, there are other substances that can get into your water supply that a water softener will not remove, so testing is a good place to start.
The reason that I suggest starting here is because this same water is what you bathe in and wash clothes. So that same scale is present on you and your clothes to some extent.
Another tact is to try a different detergent to remove the deposits as the dishes are washed. Detergents differ from soaps because the detergent is designed to soften the water as you wash through the magic of chemistry. You will probably have to experiment to see which works best. However, treating your water before it enters the house is the best course of action here.
As a stop gap measure you can simply hand dry your dishes when the wash and rinse cycle is complete. Right now you do this anyway.
Re: Dishwasher Question
12/12/2010 1:59 PM
The problem is probably due to hardwater, an inappropriate detergent (commercial dishwasher detergents are formulated for various water properties) and an insufficient dose of rinse aid.
Try increasing the rinse aid dose.
Also give the machine a good clean out, I'm sure plenty of people never clean the filters.
I'm assuming we are discussing a domestic dishwasher here, yes?
12/12/2010 10:38 PM
Probably the detergent manufacturers don't care that you use too much, but it is possible that you are. You don't need to fill the cavity with powder, a teaspoon is often ample. Excess powder is hard on the machine, the envirnment and the wallet. I have found that a wash with no powder (something gets in the way of the flap so it doesn't open) can be surprisingly good, but I have a Bosch which we found the best washer, just replaced by a new one after our secondhand 30year old one died. I suspect different machines will require more or less depending on their efficiency.
12/12/2010 11:40 PM
A lot of great answers (hard water).. Ever see the movie Cable Hogue?
Try his dishwashing method... Watch the flik of course.
12/16/2010 7:52 PM
A much, IMUO, under appreciated movie: setting-the American South-West circa 1890-1900, that I doubt many have, or will have the joy to see.
My most memorable scene of the pix was when Cable, Jason Robards (jr?), a lone, downtrodden sole traveling horseback across the dry, barren land, is beset upon by a couple of real bad-a** characters that steal his horse, six-gun and gleefully pour-out the water from his canteen and abandon him to die of thirst in the unforgiving desert.
After many days of struggling to survive, Cable collapses and starts scratching and digging the dirt, while constantly praying, "God Help Me, God Help Me"*.
The sky grows cloudy, lightning and thunder start. Cable's fingers continue to desperately claw into the dirt. Then slowly, slowly a trickle of water seeps upward which Cable consumes to satiate his thirst.
Refreshed, Cable joyfully exclaims, "I Knew I Could Do It"*
*Reflect Upon This.
12/13/2010 1:07 AM
Most dishwashers contain a water softener unit which is an ionic exchanger in order to remove calcium and magnesium ions can resulst scale. Its capacity is not infinite so there is a conductometer built into the machine which measures the electric conductance of the water on the outlet of the exchanger. The high conductivity means the ionic exchanger needs regeneration. That means that you have to wash trough the unit with saturated sodium chloride solution. The dishwasher contains a salt tank so regeneration would be done automatically. When the salt tank becomes empty you will get a visible signal and you have to reload it otherwise the ionic exchanger will not be regenerated and the dishes will be covered with a thin layer of limescale.
If your dishwasher does not "consume" salt something went wrong: either the conductometer or the salt level meter.
Aged man is not old man...
12/13/2010 11:55 AM
GA.
Using water softener large salt tablets will a) fix your problem and b) mean you probably only need to replenish them 3 to 4 times a years....We find them here in big DIY supermarkets.....
You use far less salt AND your machine will be properly regenerated each time....
Some machines have a control to set the amount of salt water used each time, mine does. You may need to increase this slightly....till the white deposit is gone.....
As many have said already, its calcium......or your machine has a fault and is not rinsing the crockery at all.......
Best of luck.....
12/13/2010 2:27 AM
Dear Christ,
I think I need more information upon the problem.If you can answer them I can try to help you to solve the problem.
1-What kind og dishwashing machine you have. Home type, tunel type or tower type.
2-What kind of cleaning products you are using all in one tablets, powder type dishwashing detergent, liquid dosing type dishwashing detergent and brightener.
3-Where do you supply your water, if you know the hardness of your water would help a lot.
4- does any other houses have the same problem around you.
Many time doesing high brighter causes the same problem. and simply lowering the brighter concentration solves the problem. If you use brightener seperatly please add some water before you put it in your dosing unite. Hope it solves the problem If not I need to have above questions.
Regards
Hasan Arsan
12/13/2010 4:52 AM
try adding a little borax "mule team" along with your detergent during the second wash cycle. it should soften the water and eliminated the hard water residue. you may want to thoughly clean your dishwasher first by running a solution of ammonia and borax. personally, i add a little a little ammonia every time i wash dishes. your soap will react with the ammonia and do a much better job. you won't need to use a rinse aid.
12/13/2010 8:24 AM
My understanding was that the soaps have changed in the last few years to become more environmentally friendly. As a result, this buildup occurs. Installing a water softener will help with the problem.
Good Answers: 42
12/13/2010 9:53 AM
Check the following and attempt.
* Check the hardness levels of your wash water used for the dish washer.
*The amount of surfactant, liquid or dispersible powder detergent, you are using. Check the dosage level of the same. If you are adding excess quantities directly to the wash bath, this may form a complex with hardness minerals in water.Better dilute the detergent and add minimum quantities. Pre soaking in dilute soap solution before machine washing should reduce your white deposits.
*If there are more oily residues left over the dishes, better soak it pre hand in a tub filled with water added with diluted dispersion of detergent, so as to reduce soap in dish washer or need not.
*Try vinegar in small quantities as a cleaning agent for dish washer component deposits at times.
*If your dish washer is having in built dryer, don't operate. After the final wash rinse, take out the dishes, wipe with a clean fabric or sponge and room dry. This will reduce the chances of hard deposits of salt/ soap complex over the surface of the dishes.
Maximum possible suggestions are put up. It would be useful to all of us if you could provide feed back on your trials[ Which most of the members and O.Ps don't do]
Best of Luck
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 25
12/13/2010 11:51 AM
Some states in USA have just recently mandated that dishwasher detergent sold in that state remove the phosphate. You can cut back on the amount of detergent you are using until the problem goes away, which it will if you cut enough, or go to a neighboring state and stock up on the old stuff.
Funny, I have never owned a dishwasher with a built in water softener. What part of the world does this happen?
Goodness has nothing to do with it.
Good Answers: 18
12/13/2010 3:30 PM
Try using liquid instead of solid detergent.
Several months ago my very reliable and non-energy-star rated 9 year old dishwasher started leaking around the pump, so I decided to take advantage of the "cash for appliances" deal in order to save $50 on a new dishwasher. The new dishwasher is a "green-washed" energy-star model that saves water and electricity. Unfortunately, the savings come from the fact that it does not use enough water to properly dissolve solid detergents, so if I use solid detergent I end up with a white film coating on my dishes - especially on my glasses.
In order to help save the world I am now stuck using liquid detergent, which costs more and does not do as many loads per container. So, instead of "wasting water" by owning a good dishwasher I now waste my money by paying for extra for liquid detergent and the grocers waste more fuel because liquids are heavier and require more room on the truck to transport..
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
12/13/2010 3:35 PM
And so it goes.
You'll have your $50 savings eaten up within a year. Thanks for the heads up.
12/13/2010 4:17 PM
Not even powder detergents? Sad.
The "tablets" ones are a real waste of money, even if they work in your machine.
Some tablet manufacturers say that no salt is needed in the machine, but what this means is that part of the tablet has to treat the water = Less detergent = less effective.
Also, how does each part of the tablet know when to dissolve? I have 40 minute programs and 2.5 hour programs, all using different temperatures!! Thats a damn clever tablet that can sort that out!!!
If you look at the weight of the tablets, the whole package weighs half of what a cheap powder package does!! and costs twice as MUCH!!! So far less "bangs for your buck!"
With the powders and use of both detergent holders I can get very dirty pots and pans (and bits of the oven too!) very, very clean. Try doing that with tablets? They do not even fit in one of the holders on my machine!!!
I have found that careful adjustment of the amount of powder, conversant with the program, even using cheap powder brings remarkably good results.
Also I buy special very hard "tablet" salt (water softener salt) for the machine and only need to add salt 3 or 4 times per year - and our machine runs at least twice a day.......with really excellent results. And its a reduced water usage machine!!!!
In the summer I inspected some of the internal parts, all "squeaky clean"......
12/13/2010 4:30 PM
Minerals probably, I have same problem. Got some stuff at supermarket called "Lemi Shine." Use regular stuff 1st & put Lemi Shine in for 2nd cycle. Works great!
P.S. There is no salt dispenser or softener on my machine and I always use the air dry setting.
12/14/2010 3:55 AM
If you live in a hard water area, then you have just told us your problem.....
When you said:-
Did you mean absolutely no provision for them? If yes, and you are in a hard water area, then you either need to buy a water softener or a new washing up machine with a built in one......
May I suggest that you check with your local chemist to see if you can buy a hardness test kit and see how hard the water is.....or maybe your water supplier can help.....?
Did you live in a soft water area when you bought the washer? Just a thought....
I personally have never ever seen such a machine without a built in softener in either the UK or here in Germany.......I personally would be very interested to hear from other people with more knowledge/experience in such matters.....
12/13/2010 9:40 PM
We had the same problem. Someone told us about Lemi Shine, a powder you add according to the directions. Works like a miracle, we have hard water also.
My wife thinks its made in Midland or Odessa, Texas.
12/17/2010 3:34 AM
Capital Tool Industries produces ultra precision Gear Hobs for cutting Spur and Helical Gears of maximum accuracy
Register to Reply 44 comments
34point5 (1); Andy Germany (3); Anonymous Hero (1); Anonymous Poster (4); arsan50 (1); beriberi (1); EElectrician (1); EnviroAir (1); Gizma (2); Hornetson (1); jlstitt2 (1); kramarat (8); ky (2); Leonf (3); lyn (4); Qqberci (1); Ragab1952 (1); s.udhayamarthandan (1); shawdog2 (1); Smeaton (1); smithdave (1); TonyS (2); user-deleted-1105 (2)
