Previous in Forum: Polyester Gelcoat Poisoning   Next in Forum: Barber Chair Restoration - Nickel Re-Plating in Chicago
Heat Exchanger Network
12/13/2010 12:49 PM
Hi, I am designing a heat exchanger network for a threshold problem that requires only cold utility. I tried doing the design using simulated annealing but finding it difficult. Does any one have a better idea of how to generate such design? Regards, Christian.
Re: HEAT EXCHANGER NETWORK
12/13/2010 12:54 PM
What is the cold utility fluid, and what's its temperature?
12/13/2010 1:05 PM
The cold utility is cooling water at 250C.
12/13/2010 1:11 PM
Congratulations on having a job. So many qualified professionals are out of work today. You are lucky.
I'd start with this selection
Elementary thermodynamics : Parker, John : Free Download ...
and then advance to other texts which are more detailed.
Re: Heat Exchanger Network
12/13/2010 1:37 PM
Maybe I'm just behind the times, but that seems rather jargon-laden.
"heat exchanger network"?
"threshold problem"?
"simulated annealing"? (Yeah, that's an FEA term.)
What is the general nature of this HX? Shell/tube, plate/frame, nested coil, other?
12/13/2010 5:25 PM
Isn't that interesting. I give my usual "don't ask us to do your work for you" response and get a GA.
You actually try to help the OP and get OT'd.
I'll just negate that OT for you.
lyn (2); papa (1); PWSlack (1); Tornado (1)
