Previous in Forum: Flywheel Systems and Inertial Energy   Next in Forum: Recycle Fiberglass
16 comments
Photovoltaic Energy - Viable Capacitor Storage ?
12/16/2010 11:41 PM
Dear experts,
Is there any available capacitor type storage units on the market, for storing solar photovoltaic energy produced during peak cycles, which can later be used during off peak times with a minimum of energy loss ?
Thank you,
PH
Re: Photovoltaic energy - Viable capacitor storage ?
12/17/2010 3:16 AM
Why capacitors? Deep-cycle batteries are used normally.
Good Answers: 29
12/17/2010 8:28 AM
Quite!
Good Answers: 130
12/17/2010 10:41 PM
Why "Quiet!" - are we not allowed to mention 'super capacitors' or something?
Good Answers: 74
12/17/2010 11:47 PM
The Twain Has Met
Good Answers: 32
Re: Photovoltaic Energy - Viable Capacitor Storage ?
12/17/2010 10:41 PM
You need very large capacity capacitors to store the energy. Perhaps it will be ideal to make these capacitors using basic theory and from long lasting material. I think it is worth discussing as Batteries, particularly Lead Acid do not last long and also are hazard due to Lead involved.
Many of you may have good idea about making capacitors from foils and simple dielectric like polypropylene or polyester. Perhaps Mylar films with high voltage breakdown can also be tried.
Assume that you want to store 10kW energy on capacitors, then see if that is really feasible as very large capacity capacitors or supper capacitor for high voltage not going to be all that easy. Storing in ionic form is much easier so it is done now, but what you can see for future is yet to be explored and is a good engineering problem.
Good Answers: 16
12/18/2010 2:18 PM
I have no experience with ultra-caps, but some things ringing a bell in my mind:
  1. I recall that they may have higher self-discharge rates than batteries. This may be a problem if storage takes place over longer periods.
  2. Ultra-caps are often used where their very high discharge/charge rates (as compared to electrolytic batteries) are of benefit.
Good Answers: 32
12/18/2010 10:42 PM
You are not right here.
Ultra capacitors are used to store fast and release energy slowly and are often used for backup power to memory devices to keep data for long period. As these capacitors have low leakage current, they can almost work like good battery.
If you use ultra capacitors for AC Power Signal in Audio Amplifier then they sure with have high energy in short cycles running into kHz rates of charging and discharging. For this one needs Gold Capacitors for higher voltages and high capacity with low noise and not those low voltage several Farad level capacitors used for memory data backup.
Good Answers: 16
12/23/2010 8:44 AM
Thanks Shyam, I stand corrected! (That is why I'm on CR4 - I need to keep up with technology's march!) Would your answer also be true in power applications (100V+, 200Ah+ systems)?
BTW, any good on-line places to do a bit of research on them? The suppliers' sites often glow on the positive, neglecting to highlight some negative or limiting issues.
Good Answers: 32
12/23/2010 9:25 AM
Polypropylene, Polyester, MKP, SF6 capacitors perhaps may be suitable to store charge for short back up time less than 1 hour and leakage resistance need to be 1000G Ohms order. Aluminum capacitors leak very fast.
Hobbies - Fishing -
12/17/2010 11:04 PM
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
12/18/2010 1:59 AM
We're on our way to achieving capacitor type storage units. There's already a screwdriver on the market that gets it's power from a capacitor. See it at:
http://www.popularmechanics.com/technology/gadgets/4223118
Also, a friend of mine said there was some street lights in Mexico that are powered by capacitors. The capacitors are charged during the day with solar power and the capacitors power the lights at night. Seems like an efficient system to me. However, the initial cost may be such that conventional grid power may be more economical today.
But what about tomorrow?
12/18/2010 5:27 AM
Capacitor energy =0.5*C*V*V, where
C = capacity in Farads
V = Voltage, Volts
Average output for 1.5KW array is 5.5KWH per day,
ie 5500W*3600secs = 19 800 000 Joules.
To store 19.8MJ at say 400V, capacity required is
19 800 000/0.5/400/400 = 19 800 000/80 000 = 1980/8 ~ 250 Farads.
Electrolytic caps:
One farad of electrolytic caps 400V occupies about 2 square metres (20 sq ft), 150mm high (6 ins). That is about 250 capacitors at $20 each.
Total cost ~ 62 500*$20 = $125 000.
Super caps: one Farad at 5 Volts costs say $5.
Total cost = 80*250*$5 = $100 000, a saving of 25%. Go for this one.
12/18/2010 1:12 PM
No $125 000
it must be $5 000
250*$20 = $5 000
12/18/2010 4:29 PM
one farad = 250 caps, 250 Farads = 62 500 caps.
12/23/2010 5:07 PM
Errors in my calcs.
electros: 62 500 caps at $20 = $1 250 000.
super caps: 80 caps in series make 1/80 Fd at 400V.
6 400 caps make 1 Fd at 400 Volts.
250 Fds total cost = 6400*250*$5 = $8 000 000.
12/18/2010 3:27 PM
Frankly, other types of energy storage are much more efficient and cheaper than caps. If you are looking for an alternative to batteries, try using compressed air or a flywheel system. You could even use a water/gravity system.
Caps are expensive, not efficient, and electrolytic ones have a bad habit of exploding....
Reply to Forum Thread 16 comments
34point5 (1); Anonymous Poster (2); gideon (2); ky (1); lighthasmass (1); PAPADOC (1); Phaddy (3); PWSlack (1); RDGRNR (1); Shyam (3)
