Previous in Forum: HVAC - Changing Refrigeration System   Next in Forum: Liquid Piston Turbine Engine
8 comments
HVAC
12/17/2010 11:13 AM
I want to know how do we change tonnes to BTUs and vice versa.In my native africa we used BTUs ,ie british thermal unit,but it seems in this part of the world they know tonnes much better than btu,eg 60 000btu how many tonnes.Thank you in advance.
Re: HVAC
12/17/2010 11:39 AM
144BTU/pound.
There are on-line converters that will do the math for you.
Re: HVAC
12/17/2010 11:53 AM
One ton is 12000 Btus (of cooling)
Re: HVAC
12/17/2010 1:29 PM
I should have said 12,000 BTUs / hour
Good Answers: 299
Re: HVAC
12/17/2010 12:02 PM
"144BTU/pound". Here is a little more explanation.
The latent heat of fusion for ice is 144 BTU/lb. For one ton, that is 2000 lb x 144 BTU/lb, or 288,000 BTU. Refrigeration's roots are in the ice making industry, and the ice guys wanted to convert this into ice production. If 288,000 BTU are required to make one ton of ice, divide this by 24 hours to get 12,000 BTU/Hr required to make one ton of ice in one day.
This well worded expansion of lynlynch and rhkramer's comments is from the internet, but now I cannot find it again to properly credit it.
Re: HVAC
12/17/2010 12:14 PM
Thanks. I suppose I was too economical with words.
Re: HVAC
12/17/2010 1:53 PM
It is important to realize that 144Btu/lb, i.e. "latent heat of fusion", is the amount of energy required to change the phase of water from a liquid state to a solid state. The point being that the liquid water begins the process at 32F (0C) and ends the process at 32F (0C); not STP, for example.
Apologies if this appears obvious, but I frequently encounter misunderstandings surrounding this concept.
Re: HVAC
12/17/2010 12:38 PM
Note carefully that in Doorman's GA explanation, a ton of refrigeration is a rate of 12,000 Btu/h. In your original example, it would be 60,000 Btu/h = 5 tons of refrigeration (TR). (I've underlined the /hr (per hour) part for emphasis, but it wouldn't normally be underlined.)
Re: HVAC
12/17/2010 1:23 PM
There might be a possible variation. In Japan and some other places, there is a Japanese Refrigeration Ton (JRT) that equals freezing one metric ton of water per day, which is about 13,200 Btu/h (I forget the exact number).
Register to Reply 8 comments
Aerodeo (1); Doorman (1); lyn (2); rhkramer (2); Tornado (2)
You might be interested in: BTU Meters, HVAC Services, HVAC Controllers
