Previous in Forum: How Do I Test an Oscillator   Next in Forum: 9V LED Timer Circuit Question
22 comments
Sound System For A Large Auditorium
12/17/2010 1:08 PM
The project is a large auditorium (1200 person capacity) and sound system is to be designed.
This is not my first auditorium design that means I am familiar with reverbration time calculations, absorption coefficient of materials, standing waves so on and so forth.
Problematic area is that this time the architecture is circular shape with the main stage projecting inwards with reference to the periphery walls, not only the microphones are there on main stage but seven language interpretation system (Philips) in the front rows of the hall does have individual microphones on each seating.
For the disposition of the Loud Speakers not only the microphones are to be considered but the large audience must not distinguish between the outputs of different Loud Speakers.
Has some one first hand experience with audio system of a large auditorium? Comments and suggestions are welcome.
Knowledge sharing is a WIN-WIN situation
Good Answers: 918
Re: Sound System For A Large Auditorium
12/17/2010 7:06 PM
Sounds like you are in a pickle.
What you want is free advice on sound reenforcement. However, most people with the level of knowledge tend to sell it rather than give it out freely. It like a bricklayer asking his competitor for free advice on doing a job.
You may end up paying for a consultant to do this job.
However, you might try asking this question at DIY Audio Forum. There are a lot of professional people on that forum and maybe one or two might be willing to help.
The forums are bot specifically for sound reinforcement, but many members are professional audio people and have a long list of credentials.
12/17/2010 7:56 PM
The query does not relates to sound re-enforcement.
Since no hard and fast rules or formulas apply it is a simple matter of sharing experience.
Dear 'Anonymous Hero' thank you for responding, I appreciate your effort.
Good Answers: 918
12/17/2010 8:22 PM
There is also modeling software for doing what you want (if I understand your request), but like anything good, it is going to be expensive and the degree of what you get out of it results-wise depends on how skillful the operator is.
I am not sure what you meant by "no hard and fast rules or formulas apply" or exactly what you were referring to.
12/17/2010 9:59 PM
If the sound system feeds to multiple speakers at substantial distances apart, it seems that any single listener could receive delayed sound from more distant (but therefore quieter) speakers, sort of an echo effect.
The first arrangement that comes to mind is say 6 speakers in a circular array at the center of the room. (The quantity would depend on how wide the dispersion angle is.) This can only be considered a starting idea.
12/17/2010 11:44 PM
"If the sound system feeds to multiple speakers at substantial distances apart"
There is a limit to maintain separation among speakers, when the speakers are placed at a substantial distance apart this is what causes the listener to distinguish more than one sound source,
Hobbies - Fishing -
12/17/2010 11:07 PM
Headphones.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
12/17/2010 11:39 PM
Headphones are there for someone who would like to listen to the language interpretation in a secondary language. It is an auditorium and speakers are mandatory.
Good Answers: 74
12/18/2010 12:00 AM
If in doubt hit them harder
The Twain Has Met
Good Answers: 130
12/18/2010 1:52 AM
Yeah - that always works;
12/18/2010 6:10 AM
I am in no doubt that the project will be successfully accomplished but as for your proposal of hitting harder, am doubtful that my employers would consider it worthwhile. 'ky' please be merciful on my job.
Good Answers: 74
12/18/2010 5:09 PM
Sorry for following my instincts
The Twain Has Met
12/18/2010 11:27 AM
Hello mountk2,
I sympathise with your challenges on this one. I had a curvy boardroom which once regularly had problems ringing with feedback and sounding very hollow in telco conferences etc.
I strongly recommend you put ALL microphone feeds and other sound sources which will be played through the loudspeakers through a recently designed professional DSP system. Some of these now have features which 'listen out' for ringing feedback which will inevitably happen from time to time in your shape of venue, and reduce the signal gain temporarily after a few seconds until it stops. I can't stress enough the importance of opting for a DSP (digital sound processor) which is as new as possible. Even new units which have subsequently had software updates since installation have experienced significant improvements in sound clarity.
There are other 'tricks' which will definately help like specifying microphones which have a very directional response with gain at the front but much less response to any sound sources to the side or behind, so reflections get picked up less. They should be of a type to handle high sound pressure levels (SPL) so they can be used close to the mouth of the person speaking so their voice is much louder to the microphone than any other sound (either direct or reflected) coming back to the mic from the speakers.
If the venue permits, please use as much non reflective (to sound) material or even absorbent material as possible in the venue itself. The biggest problem is that both your sound source(s) and loudspeakers are inside a huge acoustic mirror which has a line of foucus towards the centre of the venue, so anything which deadens the reflectiveness of that surface or even disperses it is an excelent idea. People used to use egg boxes to line walls in home recording studios for this purpose for example, but in large venues it is possible to use acoustic wadding (absorbent) on the walls with acoustically transparent but nicely decorative cloth or fabric stretched flat over the front, which from a distance look just like wallpaper or a painted surface.
Hope some of this ideas might help!
CT
12/18/2010 2:20 PM
Dear Guest; I am delighted with your participation.
You have provided very valuable advise but kindly permit me to discus the matters in the right perspective;
DSP and directional response microphones are very effective against reflected sounds but fall short of expectations if the loudspeaker(s) happens to fall in direct line of sight of the microphone and in such an event as a minimum howls or whistles dominate the speech.
As for the auditorium not only the main stage is projecting inside the hall but there is a double decker seating arrangement at the opposite end so an array of suspended speaker columns from the celling would not effectively cover the audience in two tier formation and placement of loudspeaker columns at the walls would be necessary.
I agree that absorbents like curtains are very effective to control reverberations. In the auditorium the architect has agreed to provide plaster of paris tiles for wall cladding as well as for the dome celling with beam effect for dispersion. Plaster of paris has high absorption coefficient and my assessment with Sabine formula is that things would be fairly normal.
If sound waves deflecting baffles are provided on the sides of some speaker columns the microphones will not get the undesirable sourcing direct from the speaker columns but the Architect is not conducive to the idea on account of aesthetics, architectural disfigurement etc.
The norms at this forum are that for expression of thanks Good Answer score vote is cast and I am rightfully expressing my thanks to you - GA
Good Answers: 918
12/18/2010 2:48 PM
I personally think you are expecting too much out of this forum and providing too little in the way of critical information.
All of us love a challenge and as you see you are getting a lot of well meaning responses, but:
1. We are not acoustic engineers with professional sound stage crafts.
2. Designing a system like you have eluded to takes a lot of specific information that is missing from your posts.
I think it would be useful for you to do two things:
1. Consider taking your questions to a pro sound forum. Here is one example, but there are probably many, many more out there.
Not that we are not interested (we are), but you probably will get more useful information from people in the field.
2. Define your problem space with much more detail. It is meaningless to give a 100,000 foot view and expect to get answers that are on target. Frankly, I just don't know what exactly you want to know.
As for the previous post's recommendation for the use of DSP and microphones, I think that advice is probably correct. Again, we don't know your specific questions, but even mediocre equipment like Behringer specifically makes devices to cut feedback. I have one called the Shark that uses what Behringer calls Feedback Destroyer and there are much more sophisticated gear out there designed to address these issues.
Typically, loudspeakers are place ahead of the microphones on stage and suspended from the ceiling in arrays. Every professional auditorium and concert hall I have seen has arranged them as such.
Broadcasting even sound throughout a venue usually is done with line arrays. JBL (for example) makes them and so do others. You just build a stack to the desired width and height and point each individual member as required. Multiple stacks are placed or suspended as needed to provide uniform sound. Here is an example:
I really don't know your skill level in this domain, but there should be plenty of help out there that can guide you if you find the right forum and provide all the relevant information. Then follow their advice.
Good luck!
12/18/2010 11:13 PM
I have not been expecting too much out of this forum, all I wished for is a few practical useful tips relevant to acoustics related to any large auditorium - not necessarily an expert advise from another Designer.
Just for example when an auditorium is spacious there is a possibility that a large section of audience cannot pick up what actually is being conveyed to their ears due to standing sound waves phenomenon.
Standing sound waves are out of reach and domain of any of the "Cut Feedback" devices and appropriate alternate correction measures are necessary.
On my part I am carrying out vector modelling besides mathematical assessments using empirical relations however there is always a possibility that despite all efforts some grey areas would be there.
It would be inordinate to expect the respondents at any forum to indulge in designing - I readily agree to that.
Good Answers: 918
12/18/2010 11:48 PM
There are literally thousands of excellent papers, scholarly ones at that, written on the subject.
If you are serious about the field I would suggest membership to the Audio Engineering Society.
It is kind of a broad brush, but just about everything you would want to know is probably there.
The example you cite is just going to be one of scores of issues you must design for. I just don't understand what you expect to really get here. Obviously DSP is not a magic wand, just another tool in the toolbox to combat one of many, many issues this job will have. There is no magic wand, truth be told. Only knowledge and experience will get the job done.
If all you want to do is swap old stories about acoustics, that is something else. You probably have more knowledge than me on the subject. I have been out of the field for a long time now.
You wrote, "I have not been expecting too much out of this forum, all I wished for is a few practical useful tips relevant to acoustics related to any large auditorium - not necessarily an expert advise from another Designer."
Reading that tends to tell me you are lost and don't even know what questions to ask. So if that is true the best tip I can give you is to figure out the questions first. The answers are much easier to get and to understand after you master the right questions.
12/19/2010 12:05 AM
This is yet another area that I'm not an expert in.
What I do know, is that there are sound guys out there that have a sixth sense when it comes to this stuff.
I doubt the answer will come from any forum, he needs to get one of those people on site. It will cost far less than not getting it right and paying for a redo.
12/19/2010 12:35 PM
You might also consider joining ALMA International
As a former member, I know that these guys are at the cutting edge of technology.
I agree with AH's comments, too.
Good Answers: 60
12/19/2010 2:31 PM
Good Answers: 60
12/19/2010 2:36 PM
acoustic design forums search on google produced
http://www.google.co.uk/search?q=acoustic+design+forums&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=mF0OTZjpHNCzhAfK3fW2Dg
these may be more fruitful
though if you need to ask about such a thing, Should you be designing something you plainly do not know enough about ?
Acoustic delay lines need to be incorporated in mulpiple speaker system to avoid acoustic cancelation caused by by time differences in front speaker output and rear speaker output and i know that but i am not in acoustic design.
Good Answers: 97
12/20/2010 12:38 AM
I think I think a 10.2 surround, 0.04 - 0.07 second delay and DBX Driverack would get you off to a good start.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
12/20/2010 10:33 AM
This really is a matter for a consultant. I say this as someone with extensive experience of acoustics and sound installations in studios and smaller venues (up to 500), however even with that experience I know my limitations and would use a consultant for this size of installation.
You will also run into regulatory issues in some countries with this size of venue. for instance in the UK buildings of over 500 capacity will shortly require voice alarm systems that have to meet certain stringent requirements for intelligibility and monitoring.
I would be careful of forums like DIY audio. It is good for some things but you are unlikely to get reliable advice on this sort of installation. As others have said, experts in this field are unlikely to give away their knowledge on these forums - and you need an expert. Unfortunately because basic audio is simple, the field is populated by a large number of people and even companies who consider themselves expert but do not have the expertise and who do not realise what is involved in larger installations. They are not simply a scaled up hifi or band PA.
Register to Reply 22 comments
34point5 (1); Anonymous Hero (4); Anonymous Poster (1); bwire (1); Chankley (1); kramarat (1); ky (2); lighthasmass (1); lyn (1); mountk2 (6); peterg7lyq (2); Tornado (1)
You might be interested in: Speakers, Stage Lamps, Seating
