Previous in Forum: Rotating Gearing Wheels in Geared Motor   Next in Forum: AS 2885 Pig Launcher Welded to AMSE Sec Viii Div 1 End Closure
Water Ring Vacuum Pump
12/17/2010 9:07 PM
What is the ideal height of installing a water ( liquid) ring vacuum pump. I am using this for an extruder and the vacuum chamber is at an height of 74" from GL.
Re: water ring vacuum pump
12/17/2010 9:40 PM
It isn't critical, so you could base the decision on 1) convenience of reaching the pump for service, and 2) short run of pipe from the vacuum chamber to the pump.
Reply to Forum Thread
