Previous in Forum: Turbine Generator Rotor Storage   Next in Forum: PG&E Lying?
Nozzel Distortion or Bend in Pressure Vessel
12/18/2010 12:03 AM
During inspection of a pressure vessel, a nozzel (2") distortion (bend) noted and is due to welding only. please specify acceptance limitation in any plane.
Re: Nozzel distortion or bend in pressure vessel
12/18/2010 12:37 AM
If the drawing specifies any tolerances for angularity, you could follow those. I don't know how or why a bend could be due to welding only. Maybe the nozzle crashed into something after fabrication?
Re: Nozzel Distortion or Bend in Pressure Vessel
12/20/2010 4:50 AM
+/- 0.5 degrees-deviation from horizonta,vertical or the intended position in any direction.(as per pressure vessel handbook-vessel fabrication tolerances)
Karthik
12/21/2010 9:12 PM
The vessel manufacturer and its client (not always) should have a specification or standard drawing specifying fabrication tolerances for pressure vessels.
Anonymous Poster (1); karthik144 (1); Tornado (1)
