Previous in Forum: Change in Motor Rotation   Next in Forum: Earthing System Without Earth Grid
20 comments
Crane Slip Ring Motor
12/19/2010 5:04 AM
Hi, were having problems with slip ring motors on 2 separate cranes. The rings burn up with in about 4 to 6 months. Once they start to burn its only days before we have to change the motor. Not easy to change, and expencive by the time the motor has been sent for repair. We are lucky having a spare. Any ideas what is causing the burning?
Re: Crane slip ring motor
12/19/2010 6:36 AM
Someone may have a "magic idea", but otherwise, I think you have to dig out (and then provide) some more information. Some things to do off the top of my head:
  • Have you checked (and maybe even monitored--i.e., put a chart recorder on) the motor current--that is, both the incoming current from the power supply, and the current in the wound rotor?
  • Does the crane duty vary, either in cycle time or load--try to measure those current under the heavy loads.
  • Are the crane operators operating the crane properly--are they trying to use too high a speed for the given load?
  • Do the same group of operators operate both cranes (or is even one operator using both cranes)--when collecting the load currents, correlate them with the operator.
That should give you (and maybe us) some clues.
12/19/2010 7:54 AM
The cranes operate at high speed as magnetic loading cranes. The line current isn't abnormally high, there's no change from a new motor to one that's on its way out. The motors are Brook Crompton (can't remember the frame) 60HP. The brushgear is inside the main motor body. 2 brushes to a ring, bush wear is OK until the rings start to pit.
The operators are a bit heavy handed (they don't know what slow is) but this has been going on for years with several changes of driver crews in that time. The cycle time can't be slower or they fall behind.
Will try to get more details when I go to work.
12/19/2010 10:56 AM
Sounds to me like it's down to a money thing.
Which will cost you more?
Running motors hard and having a reduced life. Or slowing down and extending motor life.
If you're thinking long term, it may pay to invest in another crane and operator.
Any piece of equipment that's pushed to it's limits on a regular basis is not going to last as long.
Good Answers: 804
12/19/2010 1:07 PM
I agree, this is an economic issue. The big clue is right here in your (the OP's) statement:
"The operators are a bit heavy handed (they don't know what slow is) but this has been going on for years with several changes of driver crews in that time. The cycle time can't be slower or they fall behind."
The reality is, your motor can only accelerate the loads at the limits of their capacity. If you attempt to accelerate them faster, you exceed their capacity and cause damage. It's a plain and simple as that.
So you either A) replace them with larger motors and controllers, in which case I would recommend a good Vector Control VFD. Or B) set up a system by which the operators are limited in the speed at which they can accelerate, i.e. a forced time delay between resistance step changes.
There is still option C) however; leave it like it is and continue to damage the slip rings. By the way, you are also most likely damaging the motor insulation as well, it is just more incremental and will take longer to become obvious. So you can invest in extra motors and keep them ready, then put quick-disconnects on them so you can swap them out with minimal down time and send them to be continually repaired.
Good Answers: 181
Re: Crane Slip Ring Motor
12/19/2010 4:04 PM
With you saying 60HP Brook Crompton with internal brushgear you set alarm bells ringing with me. I've had dealings with these motors before. If you've got one on stock as spare at the moment use a DTI to check the concentricity of the rings.
My first dealings with them was over 20 years ago, we had no spare (it was away for new rings) so I hand ground the rings on site. It's not a job for the faint hearted, we must have used 10 sets of brushes before I was happy with the rings. It ran for 7 years after that without trouble.
I then moved to a different company, the dammed things came to haunt me there. Same trouble but lucky for me it wasn't my plant, so not my problem, until they moved me. After I'd moved on to the plant I asked how much repairs were costing, motors were being sent away for silly things like bearing changes. Thing we could do ourselves. I brought all repairs back in house except rewinds. This was where I met up with my old friends again. A new set of rings arrived so I tried them on the shaft, there was 1mm of play. I had a sleeve made for the rings so that they ran true. The other motors I put in the lathe and trued the rings. No problems after that.
12/20/2010 12:21 AM
Yes eccentric rings will soon cause a problem.
To check this on a new motor, test the run out with a dial indicator it will soon pick this up.
With existing motors do some inspections to see if there is a burnt patch on one part of the slip rings, if there is pull the motor and have it machined as it will only get worse.
Excessive vibration of the motor mountings can also cause this.
12/19/2010 4:50 PM
I've seen the same effect on slip ring motors when the M-lead resistors aren't balanced or have loose connections. Check your resistor bank resistances at the motor (all three) while bringing in the speed contactors (without directional T's). Since it's 60 HP, I assume this is the hoist motor. If the speed contactors & resistors are not trolley mounted, give your festoon wiring a thorough ringing. I had a very similar anomaly while working as a crane service tech and it finally turned out to be an intermittent open in the trolley festoon. Good service technicians hard to find where you are? I have a friend...
Steve
Good Answers: 181
12/19/2010 6:03 PM
I've had the same fault with crane resistor banks and festoons. It usually causes a patchy patina on the rings not burning. The last one, one ring was fine, the other two looked like a bit of modern art. A b**tard to find though!
Good Answers: 58
12/19/2010 5:33 PM
For sure everything has to be perfectly true. You say magnetic loading cranes, there could be a lot of aggressive, maybe conductive dust around. I would examine the ring area for contaminants, this sounds like a good place for WD40, too.
mike k
12/19/2010 10:47 PM
Have you read about any other Rings in the manual,There are O Rings that
have something to do with the Oxygen sensor and are connected to the Vacuum
Hoses. If the Operator is being gassed by it, It would be hard to think straight.
The Flywheel inside the transmission could be in wrong.
Id try using a better heavy duty Service vehicle engine Oil and Gas treatment
fluids ,it refers to the service wear on engines on the label , few do.ds
Reply Off Topic (Score 4)
Good Answers: 130
12/20/2010 12:39 AM
Using reverse as a brake is a likely one. Particularly if you are paying on piece rate.
Good Answers: 25
12/20/2010 5:50 AM
Yard Cranes are subjected to heavy duty work. What is rating of the motors are they rated for Class IV contineous duty? If motors are not rated for the application required then they will performance problem. Crane mfr can suggest some solution as Crompton motors are good motors.
12/20/2010 6:39 AM
I've checked the rings on the spare motor, they run out by .5mm. I'm sending it back to the repair shop to get it put right.
All I've got to do now is persuade the powers that be to systematically change the motors so they can all be checked / trued up. At least if its planned there won't be the mad panic changing them.
Tony, how big a job is it to turn the rings in the lathe?
Good Answers: 181
12/20/2010 6:29 PM
There's two ways of tackling it.
Bore out the GRP core of the rings and press fit a steel sleeve with a key way. I had the sleeve made 50mm larger than the shaft. Be careful that the connections are orientated correctly.
If you have a large enough lathe machine the rings when mounted on the shaft. It means having the entire rotor assembly spinning in the lathe so be careful. Remember to cover the bearings. Once turned I used to finish the rings off with a "Martindale" stone.
Good Answers: 21
12/20/2010 12:06 PM
Unlike others I don't see the operation or operator as the fault. I appears to be something with the rebuild or wiring to each unit. I would assume that the same folks are working on each of the two cranes having the issue with motor. If so you need to take them by the hand and properly trouble shoot the cause not repair the after effects. These is one of the issues I have had to deal with with Maintenance folks over the years, proper trouble shooting.
06/23/2011 9:24 AM
I, for one, did not put the blame on the operators. I'm not sure anyone did. But, I did suggest that this is one of the things to be investigated.
12/20/2010 12:33 PM
The burning occurs when not proper contact between brush and ring! This motor need to be taken care of quite often. Thus it is not popular any more. The answer is frequent maintenance, especially elimination of dirt and metal shavings and lubrication with silicon lubricant should eliminate that. Also frequent start-ups add to the problems. How often have you polished the ring-slip surface? It seems you prefer more work than maintenance! Do you have proper spring on the brushes? Perhaps you need to replace brushes rather than rings.
Good Answers: 181
12/20/2010 6:04 PM
No form of lubrication should be allowed on either the slip rings or brush holders. The lubricant will mix with the carbon dust to form a sticky paste that will cause the brushes to stick in the holders. The graphite in the brushes provides the only lubrication needed.
Polishing the rings will remove the patina from the ring surface. The build up of the patina is essential to good conduction. Slip ring patinas are a formation of approximately 75% copper oxide, 20% graphite, with water and environmental contaminants making up the remaining few percent. The balance of these ingredients is critical to the proper brush and slip ring life.
01/02/2011 7:43 PM
Dirt.
06/23/2011 6:13 AM
The primary cause is persistent unequal load distribution between brushes
This slip ring file may help.
Reply to Forum Thread 20 comments
34point5 (1); Anonymous Poster (6); fixitorelse (1); garth (1); JRaef (1); kramarat (1); mike k (1); PWSlack (1); rhkramer (2); suresh sharma (1); TonyS (4)
You might be interested in: Slip Rings, Metal Ring Seals, Motor Test Equipment
