Previous in Forum: Suction Throttle Valve   Next in Forum: Efficiency Required for Machine Modification
How to Calculate Flow Rate?
12/19/2010 6:53 AM
Dear members,
If the internal diameter D of a pipe and the pressure P of water flowing through this pipe is given then how can we measure the flow rate of water flowing through this pipe?. I need a equation that show the relation between these three quantities?.
au.umair
Re: How to calculate flow rate?
12/19/2010 7:42 AM
12/19/2010 9:09 AM
don't confuse pressure with volesity
Re: How to Calculate Flow Rate?
12/19/2010 11:56 PM
Please consider these equations: Hazen-Williams, Darcy-Weisbach, and Colebrook. You need a different set of three quantities; in particular the equivalent length of the pipe in question.
01/04/2011 11:01 AM
Flowrate is not related to pressure. The pressure can be high and a shut valve can make the flowrate zero, for example.
Flowrate through the pipe is related to pressure drop along the pipe by the Darcy-Weisbach generalised flow equation, which requires rather more than two parameters to calculate the flow. Unless the values of these other parameters are known, the quest for a calculated answer for the flowrate will prove fruitless.
Register to Reply 4 comments
lyn (1); phoenix911 (1); PWSlack (1); Tornado (1)
