Previous in Forum: Question About Scuba Tanks - At Ambient Temperature   Next in Forum: Thanks for 2010 and Happy 2011
42 comments
Sound Created by the Brain?
12/28/2010 6:00 PM
I read an article about the process of playing two different frequencies,one through each ear, and the brain would perceive the difference frequency.I cannot seem to find the source of the article.Has anyone else read about this? Supposedly one can "hear" frequencies below the normal hearing range using this method.
Re: Sound created by the brain?
12/28/2010 6:09 PM
I don't doubt that each ear, and your brain, can hear two different frequencies.
I doubt the other. What do you consider the, "frequencies below the normal hearing range" to be?
Re: Sound Created by the Brain?
12/28/2010 6:17 PM
This sounds like the phenomenon of "beats," in which two sound waves of nearby frequencies add up to a low-frequency sound. This is useful in tuning pianos and other instruments.
12/28/2010 6:18 PM
I'm not familiar with that, but I saw a show on.....I think Animal Planet the other night about forest elephants. They made a recording during the night in a clearing where the elephants hung out. When replayed at normal speed, it was nearly silent.......when played back 3x faster, communication between the elephants was clearly audible. They were communicating at frequencies below our range, speeding up the recording made it audible.
Good Answers: 114
12/28/2010 7:30 PM
I heard a report once on scientists trying to find out why some voices carry while similar voices didn't. Examples were the opera singers who don't use amplification, and drill sergeants. When controlled for volume and for pitch, some carries and some didn't.
They found that the voices that carried, had additional tones above the frequencies humans can hear.
There is an explanation of Tornado's point at this link, which I use to tune the guitar that I hope to learn to play.
Go to "Just getting started", here.
Good Answers: 146
12/28/2010 8:43 PM
This research is a bit "sixties" and I'm not sure what, if any, scientific documentation of the effect is available - the binaural beat is what it's called. The sound and light entrainment theories/devices are (to the best of my knowledge) based on research results which are fairly equivocal. Afaict, there's not a strong statistical predictive value for effects of these techniques on individuals (as with hypnosis, susceptibility is variable).
Normal range of human hearing is above 20 hz, the infrasound frequencies below that can be felt but not 'heard' per se - by a human.
Great idea, Kramarat, if we speed everything up X3 we should be able to hear the elephant in the room!
incus opella
12/30/2010 9:09 PM
He said 3 x faster not 3 x as fast.
Good Answers: 69
12/29/2010 9:28 AM
What you actually hear is harmonics, and they are not below human hearing range, but their modulation is ringing at very low rates, even below 1 Hz.
If you had only one functional ear, you should still be able to hear the effect.
Yahlasit
12/29/2010 1:35 PM
I know a number of people who brains make this sort of hollow tone that is similar to what a sphere under a high vacuum makes when tapped on.
This sound seems to come out most often when ever I ask them a question that requires common sense or rational thought and or some degree of intelligence to solve.
Anyone else ever experience this phenomenon when talking to someone?
12/29/2010 2:09 PM
If I turned the volume way up, I thought I could hear such a sound whenever the OP responded to a question in this thread: Liquid Piston Turbine Engine.
Good Answers: 204
12/29/2010 11:21 PM
pretty sure that was a harmonic to the HHO 13 lies.
12/30/2010 8:14 AM
That is a big GA! I also heard it as "...the emptiest barrels make the most noise"
What is right is not always popular. - What is popular is not always right.
Good Answers: 69
12/29/2010 4:32 PM
In fact it is pretty simple; see, the brain is not a sound mixer, both sound frequencies create a patern where they interfere with one another OUTSIDE of your brain, then you perceive a slow drifting siren-like sound, the closer both waves are, the higher the resulting sound, until they coincide for just a moment, then start drifting away from each other, giving you a low pitch sound, the cycle repeats.
Try overlapping two frequencies on a scope display and you'll understand it in an instant.
Do you remember the story of a little black kid, son of white mother and black father? every time he saw his father, got scared and ran to mom screaming: boogeyman ! boogeyman!!. There were no mirrors in the house.
Have a good one, and happy new year !!
Yahlasit
Good Answers: 96
12/29/2010 11:28 PM
Hello Yahlasit,
Actually, the brain is a sound-mixer, of sorts. There is a field of study called psychoacoustics (psycho as in psychology, not as in psychopath ) studying the perception of what we hear, compared to the scientific measurement of what is heard. One simple case in point is that a change in SPL of 3dB is a factor of 2 (twice or half, depending on the direction of the change), however 10dB is perceived as twice or half as loud. Most often, these studies lend themselves to issues of intelligibility, but there are many other psychological factors as well.
I am familiar with the harmonic differences between different signals, and this is used currently to create audible sound from inaudible high frequencies. Ultrasonic transducers can be caused to create a beat frequency that is not only audible, but can be steered and directed ... a pretty neat 'trick' in acoustics. It has been done some in very esoteric home audio systems, and also for military applications (annoying noises toward the 'bad guys' but not toward the 'good guys').
Acoustics can be tricky, but it's nothing compared to the brain. Just as there are optical illusions, there are also acoustic illusions. Although I am not familiar with the OP's idea, I would not be surprised to find at least a seed of truth to the story ... the only thing that baffles me is, exactly what does a sound below my range of hearing sound like? I have felt VLF audio signals before, down to about 10Hz, and that was not exactly comfortable.
Kind regards ...
"Just when I had all the answers, they changed all the questions"
Good Answers: 69
01/03/2011 4:18 PM
Hi DCaD:
Went out for the new year's eve. I absolutely agree with you, what I want to state is that the brain is not capable of processing acoustic waves, but electrical signals.
Regards
P.S. The bad guys, being bad as they are, might find the annoying noises actually pleasant.
Yahlasit
01/04/2011 12:57 AM
See my post #32. It seems that a beat frequency can be created INSIDE the brain, either electrically, or (this seems very unlikely) by mechanical sound conduction from one ear, through the brain, to the other ear.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Good Answers: 130
01/04/2011 1:42 AM
I think you're only classed profoundly deaf when you can't hear via your skull/skeleton, so transmission is there, but still sensing is via the ear/vestibulocochlear nerve
Speakers would have higher efficiency than head phones in the 100 Hz frequency range.
2¢
01/04/2011 10:02 AM
If I felt I could afford the time, I'd like to fool with this more. If I were a better mechanic (and believed I could get everything stuck back together right) I'd cut the nerves from my ears to brain and inject the signals electronically. I think that the beat would still be perceptible. I theorize that there are nerve connections between the left and right auditory areas of the brain, and that these connections are used to help in auditory localization (being able to tell where a sound is coming from).
Interesting that with headphones, many people report the sound seeming to come from the center (inside) of the head.
I need to harvest some people for my experiments (such as severing any right brain/left brain connections). I recently saw a TV show where the mad scientist left the shoes of his "experimental subjects" in a bin. I won't do that... and I'll be careful to use only lawyers and politicians, so no one will come after me.
I think headphones are actually much more efficient in the 100 Hz range and below than typical speakers . Mine go down to 20 Hz with only a 3db rolloff, whereas even my pretty good hi fi speakers can't do that. It was the speakers on this computer that I used for the goofing around reported above. They fall off pretty dramatically by 100 Hz.
When I play 12000 in one ear and 11600 in the other at very high amplitude, the sound is faint (because it is getting close to my limit for hearing) but I cannot (with headphones) hear even a hint of a 400 Hz beat. When I do the same through the air, the perception is similar -- no hint of a 400 Hz beat, but moving around even slightly (an inch one way or the other) produces pretty dramatic quite and loud spots from the interference pattern.
Good Answers: 130
01/04/2011 2:25 PM
Maybe you could use people with these. Save all that politician and lawyer mess
12/29/2010 9:08 PM
Here is an article that might apply: http://gnaural.sourceforge.net/
12/30/2010 1:48 AM
Unfortunately, the Scientific American article referred to there is not available in my university digital library, but forum members might like to know that very early editions have been scanned by Cornell's Making of America programme:
http://dlxs2.library.cornell.edu/m/moa/browse.html
12/30/2010 1:30 AM
First discovered by biophysicist Gerald Oster at Mount Sinai Hospital in New York City, Brainwave Therapy sends pure, precisely tuned sound waves of different frequencies to your brain via stereo headphones. In his EEG research, Oster discovered that when different vibrations, or sound frequencies, are delivered to the brain separately through each ear (as with stereo headphones), the two hemispheres of the brain function together to "hear" not the external sound signals, but a third phantom signal. This signal is called a binaural beat, and it pulses at the exact mathematical difference between the two actual tones. For example, a signal of 100 Hz delivered to the left ear and a signal of 107 Hz delivered to the right creates a binaural beat of 7 Hz which in this case falls into the Alpha range.
www.brainsync.com
Good Answers: 96
12/30/2010 2:53 AM
Hello SAK ...
Good Answer ... and welcome to CR4 .
Kind regards ...
12/30/2010 12:15 PM
Thank You
12/30/2010 11:56 AM
Try reading that again leaving out the word "binaural". Yes, it is true that "a signal of 100 Hz delivered to the left ear and a signal of 107 Hz delivered to the right creates a beat of 7 Hz" (which is inaudible, i.e. it is not processed by the ears). It is also true that a frequency of 7 Hz is within the alpha range on the EEG. What is not true is that this inaudible 7 Hz frequency difference stimulates the production of 7 Hz electrical brain waves. This is where binaural pseudoscience parts company with reality.
12/30/2010 1:46 PM
I think that is not quite right -- or maybe I am misinterpreting what you wrote. The beat frequency is perceived as a volume fluctuation and that fluctuation is clearly heard when (for example) tuning a guitar or piano (and other instruments). As you approach being "in tune" the beat frequency slows down, and when it becomes so slow that you can hardly perceive it, the two strings are considered "in tune". A beat from less than one Hz to 10 Hz or so is easily perceptible. As the beat frequency gets closer to 20 Hz it begins to sound more like a growl superimposed on the string frequencies.
01/02/2011 7:26 PM
I think that phph is right. The brain perceives an 107 Hz sound with one ear, 100 Hz with the other. The processing is done in the brain, there is no perceivable difference/sum of the two waves. You see a blue light, separately you see a yellow light but your brain perceives as shadows of green according to the intensity of each, if you watch them both.
I wonder if the experiment has been done with 250 Hz and 150 Hz. Did the subject hear 100 Hz or 400 Hz?
As for frequencies below 10 Hz, my impression is that you perceive them in your gut (literally). But I haven't studied any of these, in extenso, so I might be....almost right!
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
01/04/2011 12:52 AM
Check out my post #32. 250 Hz and 150 Hz together sound exactly the same through earphones or speakers: harmony. The fundamentals seem audible, the beat (100) seems inaudible and the sum is absent.
01/04/2011 12:40 AM
This is not true, as far as I can tell. You can try this yourself, if you have good earphones that enclose the ears. When you put 100 Hz into one ear and 107 into the other, you do hear "the external sound signals" in essentially the same way that you hear them through speakers (with the sounds mixed in the air). You also hear the variation in amplitude we call a beat.
He seems to be suggesting that the beat is in the alpha range and not audible. What is heard either through the air (mixed) or through headphones is a frequency between the two, varying in loudness at a rate equal to the difference in frequency.
"Hearing" beat frequencies of about 1 to 10 Hz is very common in tuning guitars. Of course, the frequency that the ear responds to is in the audible range -- only the amplitude variation is at a lower frequency that has nothing to do with the ear's ability to respond.
In any case, the sound from speakers and earphones is very similar. I experimented with placing one headphone against my temple, mouth, etc to see if there could be sound conduction from right ear to left ear, but was unable to recreate the beat (or perceive the combined left/right volume) at high or low volume, unless both earphones were on my ears. At a volume at which the tones become inaudible with the headphone lifted about 2" from the ear (which produces a moderately loud sound with both earphones on) I cannot imagine that any meaningful amount of sound is conducted through the brain via mechanical vibrations.
It seems that the brain can perceive the beat frequency via headphones even when there is
  • no audible cross talk at all between channels
  • when there is no apparent means for physical conduction of sound from ear to ear
In short, I think Oster is wrong, at least in the way this quote is worded. There is no "third phantom signal." There is only the normal beating that any guitarist can describe. His "not the external sound signals" appears completely wrong. One hears sounds indistinguishable from the external sound signals.
The only way in which the experience is different between speakers and headphones is the apparent envelope of the beat. The beat, heard through speakers seems more dramatic.
Interestingly though, when the beat is 1Hz (frequencies 150 and 151) it is barely audible through earphones but very distinct through speakers. Also, when the beat frequency is about 20 Hz, (150 and 175)through earphones one hears the fundamentals, with a slight superimposed growl. Through speakers, the fundamentals become almost inaudible (halfway between the speakers) and the growl is pronounced, sounding a little like an idling lawnmower. So maybe there is something to Oster's observations: It seems that the beat frequency is perceived differently, speakers vs earphones, if the beat frequency is low (1Hz) or high (20 Hz) but perceived similarly when it is around 4 - 10Hz.
You can download a free tone generator. There are many, but the one on this machine is NCH.
Good Answers: 114
01/04/2011 8:28 AM
Not to disagree in any way, the beat that we hear is the variation in loudness of an underlying frequency (itself being the average of the two input frequencies) that is within in our range. If the frequency of the sound itself was the beat frequency, we would not hear it, we might feel it though.
12/30/2010 1:32 AM
There may not be as many acoustic illusions as optical illusions, but an "endlessly rising tone" can be made by starting a tone at low frequency and amplitude. For a time, increase both. Then continue to increaase the frequency while decreasing the volume--but at the same time start the process over. The overlapping effect is undeniable--and rather spooky.
I recently got an earbud radio. With regular speakers, the sound seems to emanate from them or points between; with earbuds or headphones, the sound seems to emanate from within one's own head.
12/30/2010 4:34 AM
The most of radios and every tv's are based in this principle.Every phisics book that tries acoustic try this of mix or heterodin the frequencys.Same with technical books of electronics applied to radio: Always you mix two differents frequencies but close,after pass thru a no linear amplifier you get some new frequencies :f1-f2,f1,f2,and f1+f2.This is not subjetive.If this happens applying two close frequencies to diferents ears is a new thing for me.If we could hear the sum or difference of frequenies which are into the audible range not being each one is an excelent question : please tell us the anwer when you get.-
Re: Sound Created by the Brain? binaural beat
12/30/2010 11:51 AM
another person spoke of "brainsync" he was a monk for years and meditated on sounds. theoretically the brain produces a "third" beat. its not really science yet, but probably true. his cd's are relaxing but you can download reiki music for free and it help relax, if that is what you are after. i studied at Harvard, where Herbert Benson,md studied the monks for a few years and now it is science **** http://harvardscience.harvard.edu/directory/programs/mindbody-medical-institute http://hms.harvard.edu/public/news/2010/041410_corey/ Harvard Medical School CME - Clinical Training in Mind/Body Medicine Herbert Benson, MD Harvard Medical School- CME 641 Huntington Ave Boston, MA 02215 617 432 1525 its a CME course you can take. it helped me relax a lot and now i am trying to teach it. it was meant to help physicians relax
12/30/2010 12:10 PM
I think if you check "Kelly Howell" was no monk, but collaborated with neuroscientists and biofeedback therapists, to help creat the BrainSysn Program and company.
And the last time I check monks do not own company's or write books.
01/04/2011 1:04 AM
The Dalai Lama calls himself a simple monk, but he has written many books.
01/04/2011 2:16 PM
"Kelly Howell" was no monk, and second of all this is a female not male or he
01/04/2011 2:47 PM
In my statement "he" obviously refers to the Dalai Lama. A previous post had claimed that monks do not write books.
01/04/2011 4:55 AM
I'm sorry to repeat myself, but there is science and there is pseudoscience. There are people out there who make a good living from peddling pseudoscience to the credulous, whether it be selling them unnecessary vitamin pills or ineffective lifestyle gadgets or magnetic water purifiers.
This concept of "binaural beats" affecting the brainwaves is pseudoscience. A less polite name for it is tishbull.
12/30/2010 1:50 PM
There was an interesting and lively discussion on this sort of thing in this CR4 thread.
12/30/2010 2:49 PM
Microwave hearing - They can modulate it in, or any other brainwave pattern.
Good Answers: 114
12/31/2010 9:56 AM
This doesn't prove anything, but I was looking to see if I could find a quantitative value for the perceived difference in two frequencies, as in tuning a guitar.
12/31/2010 12:46 PM
Actually , your reference says that the beat frequency is f1-f2.
The Wikipedia article explanation agrees, and may be slightly clearer:
  • If the two starting frequencies are quite close (usually differences of the order of few hertz), the frequency of the cosine of the right side of the expression above, that is (f1−f2)/2, is often too slow to be perceived as a pitch. Instead, it is perceived as a periodic variation of the sine in the expression above (it can be said, the cosine factor is an envelope for the sine wave), whose frequency is (f1 + f2)/2, that is, the average of the two frequencies. However, because the sine part of the right side function alternates between negative and positive values many times during one period of the cosine part, only the absolute value of the envelope is relevant. Therefore the frequency of the envelope is twice the frequency of the cosine, which means the beat frequency is: fbeat = f1 − f2
A (somewhat unrelated) comment on the above "is often too slow to be perceived as a pitch.":
This suggests (as a corollary) that if the beat frequency were high enough to be audible as a "pitch", that you would hear a third pitch equal to the difference. In practice this is not the case, it seems to me. For example, if you play on a piano, A2 (110Hz) and C3 (130.8 Hz) you have the first two notes of an A minor chord. You perceive the two notes in harmony, but do not perceive a 31 Hz tone. (At least I don't -- but maybe the subconscious perception of that 31 Hz tone is part of what I think of as harmony?)
Good Answers: 114
12/31/2010 1:24 PM
Oops. I read it through, and had it at the difference, but picked up the wrong part to post when I went back to check. (It was one eye that was doddery, and getting in the way).
Reply to Forum Thread 42 comments
34point5 (2); Anonymous Poster (3); artsmith (1); chrisg288 (1); DCaD (2); ferquiza (1); indel (1); kramarat (1); lyn (2); MoronicBumble (9); passingtongreen (4); phph001 (3); SAK1726Y (3); tcmtech (1); Tornado (3); U NO WHO (1); van diesel (1); Yahlasit (3)
You might be interested in: Ear Protection, Headsets, Audio Headphones
