Previous in Forum: Jacking Oil System   Next in Forum: Rope Guide for Winches
Boiler Feed Water System
01/03/2011 7:10 PM
what is the purpose of 10% leak off line in BFP?
gd gadhavi
Re: Boiler Feed Water System
01/03/2011 7:25 PM
A constant throughput of fresh water tends to keep impurities from concentrating. (Assuming that the incoming water is cleaner than what is already in the boiler.)
Good Answers: 18
01/04/2011 5:51 AM
Hi gopal gadhavi,
The reason for bleeding the water off continuously enables the feed pump(s) to remain running at all times without the fear of stagnation leading to excessive build-up of heat within the pump. Without this simple control it would require the pump to be stopped during periods of very low demand, an undesirable situation.
As demand rises further you will probably find that additional pumps will be called into service.
regards,
Massey.
If it ain't broke,leave it well alone .........until it comes looking for you!
06/07/2013 1:11 PM
Dear Mr.gopal gadhavi,
Leak off line 10% need not necessarily be maintained. It can be less also.
The main idea is to limit the CHURNING EFFECT inside the pump which results in RISE IN TEMPERATURE of the Fluid and Casing. It depends upon the material construction and temp. of the fluid to be handled.
DHAYANANDHAN.S
Register to Reply 3 comments
dhayanandhan (1); Massey 726 (1); Tornado (1)
