Previous in Forum: $69Peformance Chips   Next in Forum: Blocks pressure calculation
13 comments
Good Answers: 15
Very Long Fuel Storage???
01/05/2011 9:17 AM
I did a brief search of CR4 and didn't come up with an answer to my question so I figured I'd post it. Sorry if its a repeat.
Since I'm bored during the winter months, I've been watching a lot of movies about the world after the apocalypse. They raised a question in my head.
They main character pumps gasoline out of a storage tank that has been sitting for years and uses it in his car. Assuming no contaminants like water leaked into the tank just the gasoline sitting there for a long period of time.
How long would the gasoline be useful? Would diesel last longer than gasoline?
Gasoline stored in my gas cans in the garage loses its quality quickly unless treated beforehand. So I figured fuel stored in storage tanks would lose its strength also but due to amounts would last longer but not indefinitely.
scotchdrnkr
Re: Very Long Fuel Storage???
01/05/2011 11:54 AM
Although gasoline does not technically "spoil", its quality does deteriorate when it is stored for extended periods. Most refiners assume that from the time gasoline is manufactured until the time it is used in a vehicle will be about 90 days. Various gasoline characteristics are based on this assumption. There are basically three areas of concern when gasoline is stored for extended periods. They are stability volatility, and moisture.
Gasoline Stability
Gasoline oxidizes while in storage. When gasoline is stored for extended periods of time, this oxidation results in gasoline that will create gummy deposits in the fuel induction system. Severe cases can even result in fuel filter plugging.
In those instances where gasoline is stored for extended periods, such as private fleet storage, fuel stabilizers should be added. Fuel stabilizers extend the storage life of gasoline and reduce its tendency to cause induction system deposits. An appropriate additive package should be available from the fuel supplier.
Read the rest at http://www.avalonpetroleum.com/gasstorage.htm
CR4 Admin: Modified Post
Copyright Violation: Reduced copied text according to copyright law. Please see Section 13 of the CR4 FAQ about posting copyrighted material.
01/06/2011 9:24 AM
I'm off to the naughty step.
1/3 or less. /13 or less. 1/3 or less.
01/05/2011 10:49 PM
Diesel or distillate doesn't last that long before the quality of the fuel deteriorates.
Up until the mid seventies the recommended life of distillate was 3 years...........then, because the fuel refineries were doing it it hard for a dollar (nod, nod, wink, wink), they had been working out how to get more product from the crude oil.
Enter catalytic cracking, and a few other operations. Now a problem arises........over 99% of the catalyst can be recovered.........but the small amount left (catalytic fines) cause problems with distillate, particularly in the presence of water.
The recommended shelf life of distillate is now 12 months ashore and 6 months for marine use.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
01/05/2011 10:53 PM
That was TV and movie gas. It will do that. It comes from the same company that sells pistols with a 10 round capacity that shoots 600 times before reloading and take down a bad guy at 1,000 yards with a single shot with a one handed grip.
Speak softly and carry a big stick.
Good Answers: 15
01/06/2011 6:32 AM
Now you tell me. I've been trying to find one of those guns that never need reloading since I was a kid. Never could find one.
Thanks for the confirmation of what I thought would really happen with the gasoline and diesel fuels.
scotchdrnkr
01/06/2011 9:13 AM
More bad news, Candy Land isn't a real country!!!!
01/06/2011 10:05 AM
Gasolines oxidize with time and exposure to air to form gums. Gums can cause damage to your engine. After the Refiing process there additives such as atioxidants that reduce gum formation in storage. The gum formation tendency depend on the type of crude used to produce the gasoline and he type of process employed to make the gasoline. Gasoline can last for a long period of time depending of these factors and the storage tank conditions.
01/06/2011 10:57 AM
Had a friend with a '72 Olds in his garage for 4 years ('02-'06), and he'd left 1/2 tank of gas in it that whole time (Chicago area, I would assume winters make the situation worse for the gas). It started after only charging the battery. I was shocked.
01/07/2011 4:48 AM
I live in Baja California in Mexico in Mexicali Valley. I've seen what the months of July and August can to the gasoline... and I think that it'll not be easy to find useful fuel close to this valley after a apocalypse.
"Iron sharpeneth iron; so a man sharpeneth the countenance of his friend"
01/06/2011 5:01 PM
you are looking in the wrong direction, sulphuric acid keeps in glass almost indefinitely, so does lead,learn how to make batteries, and place some solar panels and inverters in storage, store some dry batteries also(dry as in wet cell batteries that have never been filled you can buy them) then when the shit hits the fan you will have power.
for fuel for a vehicle i built the first car 25 years ago that ran without petrol on a petrol engine,(i did not invent the technology i only perfected one similar that almost did that already existed) though it is not environmentally friendly, so cannot be posted as the forests of the world as you know it within months, however will email it to you on request but can never be posted. if the world is destroyed then there would be no harm with the industrial pollution gone (request only applies to the original author scotch drinker)
Location: I come from the deep south but currently reside in the land of ice and snow, midnight sun and all that crap
01/10/2011 3:55 AM
Forget long term fuel storage, why not use a wood gassifier? Unless all of the forests are gone you should be able to find something to "roast" and create all the fuel that you need.
Might not be the most convenient way to run a car but it works!
01/10/2011 4:38 AM
Ahha!.........Ye olde charcoal burner..........basically pyrolyzates from burning wood used to fuel the car.
The charcoal burner is on the front of the truck on the left
A typical charcoal burner for a truck or car
01/10/2011 4:17 PM
I'm curious about what happens during and after distillation that causes fuel to gum up and spoil? Crude can sit in the ground for millions of years but once distilled above ground it starts deteriorating over the course of months. Stabilizers keep it usable for about 24 months. Would keeping it in temperature controlled, oxygen and light free containment help? Sort of like a wine cellar?
Is their a conspiracy? Do the suppliers add stuff to make it go bad so consumers can't buy in bulk when prices are low? Some would guess fuel prices will see $5+ a gallon in the US within the next few years again. If it lasted forever, it may be beneficial investing in fuel, not fuel suppliers?
Register to Reply 13 comments
Anonymous Poster (3); Life is Enerventure (1); lyn (2); MOBI (2); Pk 14 like a Ye650 (1); Pretendgineer (1); Pulpmillguy (1); scotchdrnkr (1); standarded (1)
