Previous in Forum: Software Needed   Next in Forum: Need to use Windows 98 Software
Try To Install Any Application On My Windows 7
01/15/2011 11:38 PM
Hi, All
I've trying to install any application on my windows 7, during the installation this message pop-up " regsrvcs.exe common language runtime debugging application has generated an exception that couldn't be handled. process id=0x140c (5132), Thread id=0x4f0 (1264). click ok to terminate, click cancel to debug.
any help
Re: try to install any application on my windows 7
01/15/2011 11:40 PM
Did the "cancel to debug" step give any information?
Re: Try To Install Any Application On My Windows 7
01/17/2011 5:13 AM
01/17/2011 1:28 PM
it is windows 7, not vista.
guds777
01/17/2011 2:30 PM
Do you think that makes a lot of difference?
EDIT
Sorry that looks a bit sarcastic: it's not intended to be; it is a genuine question.
01/17/2011 1:31 PM
it is most likely a virus. http://www.whatexe.com/regservices.exe.html
guds777
01/18/2011 8:29 AM
Hi, All
i also try to install net framework 1.1 on my windows 7 32-bit,
this error pop-up
Error 1310 Error writing to file:
c:\dotnet\Win\Microsoft.Net\Framework\URInstallPath\aspnet_isapi.dll
Verify that you have access to that directory.
any help?
Good Answers: 119
01/18/2011 4:58 PM
Win7 has a nasty habit of corrupting user accounts. Symptoms of this include installing/upgrading applications like you describe. Another symptom is that your gadgets (on the right side of the screen like weather, clock, etc) either malfunction or stop working altogether.
Last time I checked, about a month or so ago, there was no fix for a corrupt user account. Try creating a new user account and installing your app. If it installs ok, the broken user account is your culprit. If you still have problems, check with the application's distributor/manufacturer.
Hooker
Register to Reply 7 comments
Anonymous Poster (1); guds777 (2); Hooker (1); Randall (2); Tornado (1)
You might be interested in: Waveguide Pressure Windows, Windows, Infrared Windows
