Previous in Forum: Energy Saving by Improving Harmonics   Next in Forum: Destruction of Evidence?
9 comments
Harmonics
01/19/2011 12:45 AM
Could anyone help me in understanding the effect of harmonics in the facility
Re: Harmonics
01/19/2011 1:27 AM
Some harmonics (the third in particular) can generate high currents in the neutral. They are also electronically noisy and liable to give problems to sensitive equipment that may be on the line. There would be some energy losses, but that aspect is comparatively minor, so far as my layman's understanding goes.
Re: Harmonics
01/19/2011 2:07 AM
Thanks......
Yes, due to harmonics the amplitude of current increases, but could you quantify or atleast describe energy losses because of harmonics
Re: Harmonics
01/19/2011 2:45 AM
For any current flowing in a conductor, there is an energy dissipation equal to I2R. In a heater, this would be useful, but otherwise it is (at least sort of) a parasitic loss, which usually is relatively small in the overall scheme of things. Limiting this loss will save a little bit of energy. The fact of saving a small amount of energy is sometimes blown out of proportion in various power factor or harmonic correction schemes (and scams), which can be expensive for little gain. Cleaning up harmonics can be good for other reasons, though, such as avoiding damage to sensitive components. (Or burning up undersized neutral conductors.) Let me emphasize again that this is a simplified layman's view; I am not familiar with all the calculations.
There are other forum members who can describe this better, and with luck we will hear from them.
Re: Harmonics
01/19/2011 2:57 AM
Thank you
Could you send me the other forum address
Re: Harmonics
01/19/2011 3:21 AM
This same forum, namely CR4.
Re: Harmonics
01/19/2011 3:39 AM
I tried to add to the foregoing, but ran out of time.
This same forum, namely CR4. JRaef, msamad and kvsridhar, to name three, are highly professional, as are TonyS and PWSlack. In electronics, I should also mention Winfield Hill, redfred, and JohnDG. No doubt I am missing a few others, for which I apologize.
Compared to those folks, I am a layman, but I try to translate theory into lay terms and analogies that fellow laypersons can relate to. (I am also a prankster, so bring along a salt shaker.)
Good Answers: 181
Re: Harmonics
01/19/2011 8:03 AM
Going purely on experience I installed a sub distribution board fed by a 185mm 3½ core feeder cable.
The loading was supposed to be balanced, but as per usual red and blue phases took most of the load. The neutral conductor was near glowing.
Unbalanced loads due to the third harmonic can cause havoc.
Re: Harmonics
01/19/2011 11:08 AM
Thanks..... But can you suggest me practically the meaning of 3rd,5th & 7th harmonics, where it develops and what is its effect on equipment, and how does it is related to more energy consumption
Re: Harmonics
01/19/2011 10:36 AM
Yep. Google "harmonics". Lots of people can.
Register to Reply 9 comments
Anonymous Poster (1); fayequeraza@gmail.com (2); PWSlack (1); TonyS (1); Tornado (4)
