As an engineer working in Baghdad I have been asked to check and certifiy the load bearing capacity of the the roof of one the existing villas (built 1960's to 1970's ). Due to the nature of the place, most people incorporate soem kind of overhead protection from incoming mortatrs and rockets, in this case the client intends to use the formation detailed below. I can work out the load from the materials used for the IDF cover, but i am unsure as to how to perform the check on the exiting roof slab. There is one laboratory here that can perform the standard crushing test on concrete cylinders if i core the roof and take samples. But othger than that i am at a loss.
OVERHEAD SCREEN
The roof of the villa shall be protected by indirect fire by means of overhead protection as indicated in the drawing with boxes in red. Overhead protection will consist of:
- Pre-detonation layer made of: sandwich panel 120 mm thickness, foam insulated with metal cladding (both indoor and outdoor layer) composed by pre-painted steel sheets 0,7 mm thickness (minimum).
- Protective layer at 2 mt minimum from pre-detonation layer made of sand bags (300mm thickness) placed on a mild steel plate (minimum thickness 6mm) or made of 450mm sand bags layer.
- Contractor, before proceeding to do the job, shall provide engineering calculation of the steel structures and engineering checking calculation of the roof slab for the weight of the sand
