Previous in Forum: Spokes on Wheel   Next in Forum: Automotive Maintenance
13 comments
Calculating Pipeline Sizes
03/30/2007 1:56 AM
hi
Can you all help for a simple formula to calculate the size of pipe lines for chilled water lines and boiler lines
Re: pipline calculation
03/30/2007 4:45 AM
Boilers and boiler pipeline selection, calculation ! Nice Coice..
03/30/2007 5:54 AM
The pressure requirement is 4kg/cm2 the distribution is around 500 mts
Re: Calculating Pipeline Sizes
03/31/2007 10:26 AM
Please STATE your 2 problems precisely and separately.
You will then expect meaningful replies.
Only then!
03/31/2007 4:11 PM
YOU CAN GET A FREE PIPE SIZER PROGRAM DOWNLOAD ON LINE, OR CONTACT SARCO FOR A COMPLETE SET OF DETAILS CHARTS AND DIAGRAMS. USUALLY I WILL SIZE FOR A 5.2 TO 5.4 FEET PER SECOND FLOW RATE. AT POINT OF ZPD YOU SHOULD BE BELOW 2.25 FPS TO ALOW FOR AIR SEPARATION AND IN THE REST OF THE SYSTEM YOU NEED TO STAY ABOVE 4.75 FPS TO MOVE THE AIR OR GASSES BACK TO THE SEPARATOR. CONTROL AND MIXING VALVES SHOULD BE SIZED FOR A 2-3 PSI PD, YOU CANE GO TO THE KELE WEB SIGHT AND USE THE VALVE WIZARD TO CALCULATE CV AND SIZE THE VALVES. THIS SHOULD PROVIDE THE MOST SATISFACTORY PERFORMANCE WITH THE LEAST PUMP POWER CONSUMPTION AND ELINATE NOISE. I USUALLY START WITH THE FLOW RATES AND PD ON THE CHILLED WATR ON 2 PIPE SYSTEMS. 4 PIPE WILL REQUIRE SEPARATE CALCULATIONS ON BOTH. I LIKE TO RUN A SEPARATE PUMP AND MIXING VALVE ON CHILLED WATER COILS. WITH SIMPLE PID CALCULATIONS BASED ON DEW POINT, YOU CAN GET THE MOST DEHUMIFICATION AT THE LOWEST COST BY MOVING THE WATER THROUGHT THE COIL FAST ENOUGH TO STAY BELOW DEW POINT ALLTHE WAY THROUGH THE COIL RATHER THAN LOWERING THEWATER TEMPERATURE LEAVING YOUR CHILLER WHICH WOULD SERVE TO LOWER YOUR CAPACITY AND RAISE YOU POWER CONSUMPTION. ( LOWER RH- HIGHER COMFORTABLE TEMPERATURE SETPOINT.
04/02/2007 3:08 AM
can I have the site address were i can down load the program
04/02/2007 5:39 AM
It's a simple calculation.
As a rule-of-thumb, keep the velocity between 1 and 3m/s for liquids.
One can go a bit higher for gases.
Good Answers: 19
04/18/2007 8:31 AM
Pipe sizing: water/air/gas
Q = 3.142/4 x A2 x V x 3600/1000000
Q = m3/h
A = mm pipe dia
V = velocity : water 1- 10 kg/cm2 : 1.5 - 3 m/s
air 1- 2 kg/cm2 : 8 - 15 m/s
200-300 kg/cm2 : 5 - 7 m/s
03/15/2009 6:47 AM
Please elaborate the formula?
Good Answers: 19
03/15/2009 3:27 PM
For water capacity m3/hr pipeline sizing at various velocities 1.5 m/s thru 3.0 m/s based on formula:
water flow m3/hr for pipe size 15mm:
velocity m/s: say 1.5. 15mm = 225 area =
3.142 x 225 x 1.5 x 3600
------------------------ = 0.95 m3/hr
4 x 1000000
velocity m/s: say 3.0 15mm = 225 area =
3.142 x 225 x 3 x 3600
------------------------ = 1.9 m3/hr
4 x 1000000
water flow pipe size 100mm:
velocity m/s: say 1.5. 100mm = 10000 area =
3.142 x 10000 x 1.5 x 3600
------------------------ = 42.4 m3/hr
4 x 1000000
velocity m/s: say 3.0 100mm = 10000 area =
3.142 x 10000 x 3 x 3600
------------------------ = 84.8 m3/hr
4 x 1000000
you can now workout for any pipe size depending what velocity you want to keep.
Good Answers: 19
03/15/2009 3:39 PM
Keeping everything constant change velocity stated for air and gas and the same formula indicates the m3/hr compressed air flow and natural gas flow via pipe selected.
06/01/2007 10:17 AM
please let me know what will be max flow in m3/hr for thermic fluid for a pipe line size of 250 mm dia
06/01/2007 11:47 AM
You can circulate up to 5,000 cubic metres in one hour.
mm
Good Answers: 19
03/15/2009 3:35 PM
Please intimate MKcal output of thermic oil fluid.
Is it from one boiler? or a set of boilers like: 5.0 Mkcal x 3 nos
a 250mm pipe is good enough for 15 MKcal at reasonable pressure drop within limits.
Anonymous Poster (4); dnabio (1); ducon (4); MUKULMAHANT (2); PWSlack (1); sertand (1)
