Previous in Forum: BTU to Horse Power Conversion   Next in Forum: reverse/min power
power cable
02/03/2011 9:42 AM
10 motor of 10kw 7 motor of 15kw distance of 320meter now tell me what the size of cable plz send me formula of this
Re: power cable
02/03/2011 1:38 PM
There is no one real formula of this. See the gazillions of CR4 threads on cable sizing.
Re: power cable
02/04/2011 12:36 PM
British Standard 7671 again.
Contact the British Standards Institution. There's so many copies of BS7671 there that there's a sales drive on just to get rid of them.
Re: power cable
02/17/2011 9:49 AM
It seems complicated, however, I might just put it together for you :)
Load of 10 motors of 10KW each = 100KW
Load of 7 motors of 15KW each = 105KW
Total Load (not including any safety factor) = 205KW
Total Length = 320 meters
Assuming voltage drop allowed = 2.5%
Max. acceptable voltage drop (Vd) = 2.5% (415) = 10.375v
I = (205 X 1000)/(1.73 X 415 X 0.8) = 356.7A
Using the following formula:
Formula Vd = mV x I x L or mV = Vd x 1000
1000 I x L
where Vd = maximum acceptable volt drop (in volts)
I = current per phase (in amps)
mV = appropriate volt drop (in mV/amp/metre)
L = route length (in metres)
Once you come up with mV figure, then look up for the manufacturer list of four core
xlpe cable.
After studying the table to find a voltage drop value equal to, or less than the calculated one above. Then you could select the cable size in the same row in the table....
Your breaker size would be of 630A MCCB, depending on the sizing. Hoping that would help ya :)
abasins (1); PWSlack (1); Tornado (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
