Previous in Forum: Standard or Code   Next in Forum: 450Ton Carrier Centrifugal Chiller
Water Heating
02/11/2011 10:12 AM
Hi,
Just wondering if anyone can help with an equation.
I will have a know quantity in a water tank that I will be heating via a electrical element.
Can anybody give me an equation for creating a graph of energy input against time to heat to specified temperature. Also what inputs do I need for the equation.
I had 2 No. equations I found Q=mCpDT and Q=mCpdT/dt
I understand that DT in the first equation is the difference in temperature i.e from 10 degrees C to 50 degrees C DT would be 40. but what about dT/dt in the second equation. This I assume is for the change in heat transfer as the water heats (DT would be getting smaller).
Q= Energy Watts
m=
Cp=
Any help appreciated.
Re: Water Heating
02/11/2011 10:28 AM
The first equation should read
E=mCpΔT
where E is the energy needed to achieve a temperature difference of ΔT. This equation is the one needed to drive the graph, and will work up to a point close to the boiling temperature provided the vessel is well-insulated and any vapour well-contained.
Cp, or rather Cp, is the thermal capacity. It varies in the third significant digit for water between 0 and 100degC, and vor highest accuracy it is best to refer to published Steam Tables.
Power is measured in Watts (among other units). Power is a rate of delivery
of energy.
Re: Water Heating
02/11/2011 10:33 AM
Thanks. The vessel is well insulated and so I cant neglect heat transfer to the surroundings. So E I'm looking for Delta T I have. mCp is ?
Re: Water Heating
02/11/2011 11:07 AM
The mass of whatever is being heated multiplied by its thermal capacity, as stated above.
Re: Water Heating
02/12/2011 11:36 AM
Dear 21j
The dT/dt refers to the RATE OF INCREASE OF TEMPERATURE of THE HEATED MEDIUM for the given INPUT ENERGY.
DHAYANANDHAN.S, INDIA
Re: Water Heating
02/14/2011 4:55 AM
Hi Dhayanandhan,
Thanks for the reply. What inputs do I use for dT and dt?
Thanks
21j (2); dhayanandhan (1); PWSlack (2)
