Previous in Forum: Electronics   Next in Forum: Lightning Rod Usage
16 comments
How to Calculate Output Torque?
02/11/2011 11:42 AM
I have a 15 HP motor running at 1200 rpm consuming 20 Amps at 430 volts. There is speed reduction of 1.75 times in pulleys and speed reduction 0f 15 times in reduction gear box. With these parameters what would be the torque in Newton Meters at the output shaft in gearbox?
Pathfinder Tags: Electric motor torque
Re: How to calculate output torque?
02/11/2011 12:07 PM
The answers aren't in the back of the text book?
02/11/2011 12:36 PM
It is the load's characteristics that determine the torque, not the motor's.
Re: How to Calculate Output Torque?
02/11/2011 12:53 PM
The answer is 42! (cue the musicians)
I leave the analysis to the student.
02/11/2011 2:33 PM
Ah-Ha! The answer is 42, but what is the question?
What do you get if you multiply six by nine? I just love that movie!
02/11/2011 3:35 PM
Read the books, they're so much better. I miss his humour.
Good Answers: 181
02/11/2011 4:41 PM
Marvin!
You've got a lot to answer for! I always thought the answer was 47 but I can't remember the question. We need a CR4 DeeperThought computer.
Good Answers: 48
02/11/2011 5:25 PM
I dread to think of the consequences if it were programmed by CR4 members! And would Deep Thought have got a GA?
Good Answers: 181
02/11/2011 10:44 PM
Chaos theory is well established, we now need quantum chaos!
India - Member - New Member
02/11/2011 3:32 PM
Aproxmatly 532 N-m
i hope you can get this by formula t=(KW X 60000)/(2pie X rpm)
reduction 1.75times as 1.75% 15times as 15%
key questions why, what & how - just think
02/11/2011 5:46 PM
That might be the maximum torque that the motor could offer.
The load torque will be less than this, otherwise the motor will stall. And when the motor is turning the load, it is still the load that determines the torque, not the motor!
Good Answers: 48
02/11/2011 6:25 PM
You're absolutely right.
He does give us a bit of a clue with consumption 20 amps at 430v. Making assumptions regarding motor efficiency, etc. would that give us about 350 Nm ?
02/12/2011 4:22 AM
Well,
assuming it's a 60Hz supply on a 6 pole motor
assuming it's a 430V motor
assuming i's a 3 phase supply that's balanced
assuming that the belt reduction is 100% efficient (v, flat, toothed very different....)
assuming the gearbox is 100% efficient (helical or worm very different or ?...)
assuming that 20A is the flc at this voltage and frequency
assuming it's really 1200rpm (synchronous speed, no slip?)
approximately 2297Nm absorbed at gearbox output shaft (why Nm not lbft as motor in HP?)
I assume this may help, many thanks for your precise question and information that led me to this conclusion
Just out of sheer curiosity, why do you need this information, I realise this may be a stupid or irrelevant question (apologies)
Is this the answer you were looking for?
02/12/2011 2:56 PM
I am looking for this answer cause I need to replace the set of helical gear box, v-belt pulley and the 3 phase induction motor with a high torque direct drive motor with a thrust bearing. Hence I needed to find out the final torque at the out put shaft of the helical gear box.
Thanks for your answers..
02/12/2011 3:00 PM
Thank You Florence, your answer is good. The current frequency is 50Hz
02/12/2011 3:39 PM
If the frequency is 50 Hz, how is the motor running ar 1200 rpm?
02/12/2011 6:17 PM
By having a stator/rotor pole ratio of 2/5. (Or did I invert that again?)
Register to Reply 16 comments
Doorman (1); Florence (1); Holzfeller (2); lyn (1); parvathaneni (1); PWSlack (2); redfred (3); SilverCourt (2); TonyS (2); Tornado (1)
