Previous in Forum: Philippine 230/240V Two Wire System to 110/120V U.S.   Next in Forum: Gas Turbines Synchronization with Grid @ 11kV, 50Hz
Linearly Independent Proof
02/13/2011 6:08 PM
Need help with finishing this proof.
Question
Let {x1 , . . . , xk} be a linearly independent finite set in a normed linear space. Show that there exists delta > 0 such that the condition
max||xi-yi||<delta ,1<=i<=k
implies that {y1 , . . . , yk} is also linearly independent
proof:
Assume {y1 , . . . , yk} is also linearly dependent
there exist c1,...,ck not all zero s.t.
c1y1+...+ckyk=0
WLOG suppose c1=1
yi=xi+ei, ,1<=i<=k (where ei is really small)
c1(x1+e1)1+...+ck(xk+ek)=0
c1x1+...+ckxk=-(c1e1+...+ckek)
RHS span{x1,..xk}
therefore,
c1e1+...+ckek=t1x1+...+tkxk
Now, I don't know what to do. I know i need to use that fact that the norms are equivalent to prove that c1 cannot equal 1, but I don't know how to do it.
Thankful for any help
Re: linearly independet proof
02/13/2011 6:49 PM
Good Answers: 181
02/13/2011 6:58 PM
If your going to uses acronyms please specify them first. It takes a little effort and it means people can understand you! Your post is pure Gobbledegook! You'll find it on Google!
02/13/2011 7:23 PM
Please reformulate this in a browser with a toolbar that allows proper formatting of subscripts and symbols such as ≤.
Engineering and pure math are not the same; I would bet that less than 0.1% of CR4 members would know what a "normed linear space" is; e.g., I've long since forgotten.
Use δ and ε rather than "delta" and "e".
WLOG = "without loss of generality"; RHS = ??
Re: Linearly Independent Proof
02/14/2011 8:15 AM
Part of the problem states that:
c1y1+...+ckyk=0
and
WLOG suppose c1=1
At the end you say: I know i need to use that fact that the norms are equivalent to prove that c1 cannot equal 1, but I don't know how to do it.
I'm not sure that this statement is true (that c1 ≠ 1). Consider the equivalent equation:
c1'y1+...+ck'yk=0, where c1' ≠ 0, and ≠ 1. Divide both sides of the equation by c1' and you get:
c1'y1/c1' + c2'y2/c1' + ... ck'yk/c1' = 0, which can be rewritten as:
c1y1 + c2y2 + ... ckyk = 0; where c1 clearly equals 1 ( and c2'/c1' = c2, etc).
Thus c2 can equal 1.
02/14/2011 9:30 AM
The final statement should, of course, have been:
Thus c1 can equal 1.
lyn (1); TonyS (1); Tornado (1); Usbport (2)
