Previous in Forum: Kinney Vacuum Pump Not Building Vacuum   Next in Forum: Adhesive To Bond Abs Plastic To Glass
12 comments
Concentrated Nitric Acid (98% or greater) Storage Tank Specificatons
02/15/2011 9:11 PM
What construction material is recommended? I understand that (1) high purity aluminum (no Cu or Zn) or (2) high silicon (5%) stainless steel. are preferred! Also, please provide tank manufacturers, preferably in US! Thank you George Cross
Re: Concentrated nitric acid (98% or greater) storage tank specificatons
02/15/2011 9:31 PM
If the tank is safe from mechanical damage, and not too large, some plastics might also work.
02/15/2011 9:50 PM
Thank you Tornado, the tank size is for 400 tons 98% nitric acid (64,000 gallon tank). Thanks for your input!
02/15/2011 9:56 PM
Whoa, Nellie, I don't know of any plastic tanks that big, but you might be able to line a tank of cheaper metal than SS or "fancy" aluminum. (Or maybe a few smaller tanks.)
02/15/2011 10:03 PM
I'd say this will take more than one tank.
02/16/2011 5:59 AM
Thank you for your response - good point! Our current producer/supplier has two 125-ton capacity tanks, 13-feet high (for portability).
02/16/2011 3:27 AM
For inherent safety, investigate why such a big tank is being considered, and take steps to modify the process and operation so as to reduce inventory.
02/15/2011 9:56 PM
I'd ask my acid supplier what he recommends.
Cole Parmer says:
Chemical Selected
Nitric Acid (Concentrated)
Compatibility Level Selected
A-Excellent
The Materials which match your search results are listed below:
Material
Compatibility
304 stainless steelA
1-Excellent
316 stainless steelA
1-Excellent
BronzeA
2-Excellent
Ceramic Al203A-Excellent
Fluorocarbon (FKM)A-Excellent
KalrezA-Excellent
Kel-FrA
1-Excellent
PTFEA-Excellent
PVDF (Kynar®)A
1-Excellent
TitaniumA
1-Excellent
VitonrA-Excellent
08/12/2012 7:19 PM
I know this is an old post, but do you remember where you got this chart? Thanks!
Re: Concentrated Nitric Acid (98% or greater) Storage Tank Specificatons
02/16/2011 3:26 AM
Plastics, plastics, plastics.
See the Cole-Parmer materials compatibility database for an exact fit.
02/16/2011 11:30 PM
just ask your supplier where he gets his tanks from
Good Answers: 19
02/17/2011 12:08 AM
An interesting discussion regarding difficulties encountered in periodic inspection of an aluminum tank used for nitric acid storage:
http://www.eng-tips.com/viewthread.cfm?qid=71346
03/12/2024 10:46 AM
Simple. Phone the supplier of the <...Concentrated Nitric Acid (98% or greater)...> and ask. Build a relationship and maintain a dialogue over time.
The final installation will be subject to that organisation's inspection and acceptance, if deemed suitable. The supplier has a vested interest in that, for it only takes one mishap for that body to refuse to supply any longer.
Register to Reply 12 comments
Bud (1); gcros (2); lyn (2); MadeForJesus (1); Olebogile (1); PWSlack (3); Tornado (2)
