Previous in Forum: Overheating at 120 kph   Next in Forum: Looking for a "Super" Wax.
8 comments
Door Seal Guide Lines
02/15/2011 9:20 PM
I am looking for design guide lines for doors seals on ambulances and work truck as well as a consultant to help me.
Re: Door Seal guide lines
02/15/2011 10:12 PM
I wouldn't try to design this from scratch; rather, I would look for some stock rubber or foam extrusions a bit larger than the door gap. Refrigeration and automotive suppliers might be good sources, or even McMaster-Carr. If Doorman chimes in, he might have some specific suggestions. (But don't go for the LynDoor® "Universi-Gasket." One size doesn't necessarily fit all.)
Re: Door Seal Guide Lines
02/16/2011 12:30 AM
This is, I assume, a niche market endeavour.
After many hours of hard work, LynDoor™ Industries has recently developed the Octi-seal Doorjamber® sealing system that uses multiple suction cups to ensure an air tight seal between doors and the ambulance/work truck body, up to speeds of almost 13 miles per hour.
Look for it soon at your local ambulance/work truck door seal supplier.
Arnold Ka, is there really a market for this?
Google eastwood.
02/16/2011 10:04 AM
In general I agree with Tornado, why try to invent the wheel again?
However, there are circumstances where you need a different wheel. This link takes you to a list of cars with unusual doors. I can only believe each of these has some unique gasket or seal requirement that required engineering.
Can you tell or show us more of your needs? I also agree with the others that the overwhelming assortment of products from LynDoor™ Industries should be reviewed.
Good Answers: 123
02/16/2011 10:40 PM
There is more to your request than you have told us.
There is a company called Soft-Seal that manufacturers replacement door gaskets for classic cars. They could help guide you to find what you want. The common gasket material used on the compartment doors of ambulances is roughly the shape of an "L", but with the angle between the vertical and horizontal at about 45 degrees. Because the doors are usually made from 3/16" aluminum, and flat, the usual method of attaching the gasket to the door is to just glue it on.
Some times the weatherstrip will just be flat foam gaskets, also glued.
With roll up doors becoming so popular, gaskets are changing. A lip seal on the bottom of the door, and a pair of lip seals along the sides of the door frame.
Bob
02/17/2011 8:03 AM
I can help , but I need a better brief than just door seals.. Location Function,placement of seals , and location of vehicle.
Do you have drawings or pictures of the door and aperture.. if interested we can exchange direct info
Torque is not cheap
02/17/2011 10:37 AM
Thank you for responding to my question. I will pull together a package of information and get it to you
Thanks again
Arnold
02/27/2011 10:59 PM
Here is the information
Good Answers: 123
02/28/2011 9:27 PM
Nice posting. The weatherstrip you have shown would be more effective, if you were to eliminate the flat section of the weatherstrip,furthest away from the hinge, and make the remainder of the weatherstrip thicker, and allow it to intrude into the interior more. It will be better at conforming to the inevitable irregularities encountered. Another option would be to use a D shaped weatherstrip, in place of the triangle. The triangle is going to be forced to crush more on the flat side than the slopped side. That might not be good for long term sealing. I don't see it being done in the production world.
Bob
Register to Reply 8 comments
Arnold Kay (2); bob c (2); Doorman (1); lyn (1); merc600sec (1); Tornado (1)
