Previous in Forum: Compressor Temperature Monitoring   Next in Forum: Interlock Signal
Formula for Turbine Flow Meter
02/18/2011 1:00 AM
Presently I'm using a turbine flow meter (show the M3) in my PRS system for CNG flow. What is the exact formula to convert the exact NM3 reading by Turbine flowmeter which follows the AGA 7 & AGA NX19 standard????
P. Paul
Re: Formula for Turbine Flow Meter
02/18/2011 3:21 AM
First I would consult the flow meter manual to see if density correction is already built in.
You might be interested in: Turbine Flow Meters, Gas Flow Meters, Flow Meters
