Previous in Forum: Formula for Turbine Flow Meter   Next in Forum: Temperature Controller Calibration
Interlock Signal
02/18/2011 2:02 AM
Is it necessary to show the connection of interlock signal from level transmitter mounted on a fuel storage tank to inlet and outlet flow control (motor operated valves) in PID?
Re: Interlock Signal
02/18/2011 4:29 AM
It's only necessary if it required by the Client's PID Standard symbology.
Otherwise it's good practice, and may be useful.
02/18/2011 4:42 AM
Agreed. One way to show this is to use a dotted line to distinguish electrical connections from piping runs.
Good Answers: 29
02/18/2011 8:28 AM
Is the signal device represented in the logic and if so isn't it already in the I/O map?
02/18/2011 10:27 AM
Yes it is necessary to avoid the future confusion & for standard documentation.
P. Paul
p_prabir (1); PWSlack (1); RDGRNR (1); Tornado (1)
