Previous in Forum: Motor Painting   Next in Forum: VCB Failure
12 comments
Alternator
02/20/2011 12:37 AM
hello
can any one give me some information about basics of alternators.We have a 12mw gas generator build by john brown and is a 5 frame unit.the alternator section has two exciters.the smaller one is brushless i'm not sure of the bigger one.it has a 14 ton rotor.and runs at a speed of around 6500 rpm.Can you explain about the scene i have projected.i need to know about the principles of electricity generation,alternator rotor exciter bus bar connections and other panel related information
Good Answers: 181
Re: alternator
02/20/2011 3:06 AM
Read the manufactures information!
Re: alternator
02/20/2011 3:12 AM
If all else fails, read the instructions.
Re: alternator
02/20/2011 5:30 AM
The basic is that, in any ac generator there should be presence of magnetic lines of force, cutting of magnetic lines of force, before voltage is generated. The exciter is a small dc generator that produced the necessary field to be sent to the main rotor winding and due to the magnetomotive force of main rotor winding and main stator winding voltage is produced.
Good Answers: 116
Re: Alternator
02/20/2011 7:33 PM
  1. The alternator [AC generator] will run, most likely, at 3000 rev/min [50 turns a second] for 50 Hz, or 3600 rev/min for 60 Hz and have two poles (That means 1 north pole and 1 south pole, which really means the rotor has just one winding).
  2. Or it could be half the speed, a 4 pole machine, essentially an X section with two rotor windings at right angles to each other.
  3. In the past, direct current was fed to the rotor windings via slip-rings. This makes the rotor a big electromagnet with its axis perpendicular to the shaft axis.
  4. Nowadays, "brushless" is usual - that means exciter windings on the rotor pass fixed direct-current field windings on the frame. This produces alternating voltage in the exciter windings on the rotor which is rectified by silicon diodes (on the rotor) to produce direct current which is fed to the main field winding. The exciter alternator frequency is usually several times that of the main output, so that main rotor current is practically ripple-free direct current.
  5. There is often a rotor permanent-magnet "pilot exciter", overhung on the non-drive end, the fixed output windings of this give an alternating voltage, typically 240 -400 Hz which is rectified by the Automatic Voltage Regulator (AVR usually a solid - state static box ) in a controlled way to keep the main output at design voltage, despite load current and phase changes. There could be a transformer-rectifier in place of the pilot exciter.
  6. Roughly speaking, the main field voltage/ exciter are 200V while the pilot exciter is 250V. The exciter field, driven by the AVR is about 20V DC on-load.
  7. The rotor induces the output voltage in the fixed main 3 phase armature.windings around the rotor [stator windings].
Try http://en.wikipedia.org/wiki/Alternator
for more explanation.
I believe it may be the "Frame 5" gas turbine which is 6500 rev/min, with a reduction gearbox to the AC generator.
Re: Alternator
02/20/2011 10:15 PM
Hello
Thanks for the explanation.Secondly i'm not very sure about the rotor speed as the speed is transmitted through a load gear box that is connected to the gas turbine.Can you pls explain the topic via simple line diagram as i am a beginner to this feild and am from the mechanical fraternity.
all that i want to clearly know is what is in the stator,in the rotor then what exactly happens when the rotor moves and which is the magnetic field and what does the exciters do and from where does the electricity generate and then details of the bus bar and if possible the governor connections.Thanks once again and pls do post
Good Answers: 116
Re: Alternator
02/21/2011 8:03 AM
A good place to start - download this ABB demo
http://www05.abb.com/global/scot/scot232.nsf/veritydisplay/538923a1c1fa67e6c12572aa00349b96/$file/demo.zip
Some good illustrations (is your generator "Brush"??) :-
http://www.brush.eu/12194.file.dld
Do you not have generator technical manuals? - should have single line & other drawings.
The rating plates on the generator/turbine/gearbox should give speeds....
I may have to draw a diagram in the end.....
Good Answers: 213
Re: Alternator
02/20/2011 11:26 PM
Re: Alternator
02/21/2011 2:24 AM
Hello
I need a simple line diagram,b'cos the system in wiki is more related to auto powre generation,and my concern is in oil and gas sector where we generate power via gas turbines.
Good Answers: 130
Re: Alternator
02/21/2011 6:36 AM
I'd like to give you 100 GA's for proper accreditation.
But am allowed only 1
'Respect'
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: Alternator
03/06/2011 11:42 AM
nelsonaugustinec:
What do you mean by " simple line diagram"?. We will have single line diagram and control diagram only.
Anything that can go wrong, will go wrong
Re: Alternator
03/01/2011 10:32 AM
It may use a Main-pilot excitor scheme. The main excitor consists of a rotating armature along with diode rectifier on the rotor shaft itself. Its stator has a winding for creating the field. The pilot excitor consists of a permanent magnet rotor and a stator with the armature winding on it. When the turbine shaft starts to rotate, the permanent magnets of the pilot excitor rotate and create rotating field. This field cuts the stator winding hence inducing an emf in it. Now this induced emf (alternating in nature) goes to the AVR wherein it gets converted to DC through electronic converter and this is now fed to the stator of the main excitor. Hence the field of main excitor is energized. once this is done, as the rotor is already rotating; the flux lines cut the armature conductors of the main excitor generating ac. This AC passes through the diode rectifier mounted on the shaft, gets converted to DC and this DC now is fed to the rotor of the alternator thus providing it with the necessary magnetic field. An emf is induced in the stator winding of the alternator thus giving us the electrical power. The moment of rotor shaft may be because of steam passing through the blades of the turbine or gas.
mscs
Re: Alternator
03/03/2011 2:41 AM
Thanks,your answer was very concised and to the mark.All i wanted to know was the basic concept of the working principle and you have provided me with a very simple answer.Thanks once again.
Register to Reply 12 comments
34point5 (1); 67model (2); cwarner7_11 (1); hien.nguyenquoc (1); jhunair (1); MSCS (1); nelsonaugustinec (3); PWSlack (1); TonyS (1)
