Previous in Forum: Between Parallel Generator and Single   Next in Forum: Alternator
9 comments
Motor Painting
02/19/2011 9:54 PM
We have motor which has manufacturer's standard painting which is 2 coat. Now we need it painting with 3 coat. Can anybody suggest how can we do it?
Re: Motor painting
02/19/2011 10:14 PM
Just spray it one more time. If you can figure out how to apply two coats, surely you can manage three.
ξ
Re: Motor painting
02/19/2011 10:22 PM
If it's two coat now, it just needs one more coat. Then, it will be three coat.
Or, strip motor; prime coat; base coat; top coat.
Re: Motor Painting
02/20/2011 12:46 AM
Just make sure that you paint over the Information Plate. That way, future maintenance personnel will have no idea how to service it.
Good Answers: 181
Re: Motor Painting
02/20/2011 3:03 AM
Don't forget to get over spray in all the air vents and on the shaft just to make matters worse!
Re: Motor Painting
02/20/2011 3:07 AM
Cynical? Me?
Re: Motor Painting
02/20/2011 3:14 AM
Either a brush or an aerosol. Both will work.
Re: Motor Painting
02/20/2011 8:56 AM
If you don't clean and scuff up the existing finish before applying the third coat, it won't last long........same if you apply paint that isn't compatible with existing.
Re: Motor Painting
02/21/2011 12:05 AM
Hi,
Appears to be too simple. But remeber, each coat add on to paint thickness. This will reduce motor heat dissipation and hence may affect performance. If motor capacity is big, design allowance would be too low, need to be extra careful. Confirm allowable and available paint thickness with manufacturer, before going for extra coat.
By the way, why do you want extra coat? Is that a a normal practice / as per manufacturer recommendation? Motor needs only conventional cleaning.
Re: Motor Painting
02/28/2011 7:17 AM
Find and go to a Good tailor for a third coat to be done.Or Simply ask your
painter to do a spray paint. This will be very economical than going to the motor
manufacturer.
Manroop.Chennai.
Anonymous Poster (3); kramarat (1); lyn (1); Mikerho (2); PWSlack (1); TonyS (1)
