Previous in Forum: DIN standard for pipe flanges?   Next in Forum: How to straighten cold rolled section
Measurement ms Thickness vs Weight
04/03/2007 1:41 PM
sir
i want to know thickness vs weight of ms plates
suppose 2 metre x 2metre ms plate with thickness of 5mm what is the wt of plate .
if u have i want chart about that details. thanking you
gemrafi
Good Answers: 18
Re: measurement ms thickness vs weight
04/03/2007 2:44 PM
There is a little variation in mild steel density, but it's about 0.295 lb/cu in. You do the conversions and math.
Good Answers: 137
04/04/2007 5:07 AM
Exactly. But as he's clearly a metric person, I'd add density is 8000 kg/m3 as near as dammit.
Cheers......Codey
Re: Measurement ms Thickness vs Weight
04/04/2007 1:28 AM
Just short of 157Kg
7.85xt mmxArea( sq metre)
7.85x5x4
04/04/2007 12:12 PM
04/06/2007 11:59 AM
My dear,
No need to charts or tables to calculate the weight. The solution is very simple. Only see the following equation to calculate the weight :
Weight of plate in Kg = Volume of plate in m3 x Metal density in kg/m3
= [(Plate length in m) x (Plate width in m) x (Plate thickness in m)]x (Metal density in Kg/m3)
= (2 m) x (2 m) x (5 mm = 0.005 m) x (7850 Kg/m3)
= (0.02 m3) x (7850 Kg/m3)
= 157 Kg
[Legend : m = meter, m3 = cubic meter, mm = millimeter & Kg = Kilogram]
With my best regards,,,
Abdel Halim Galala (1); Bill (1); Codemaster (1); MUKULMAHANT (1); PWSlack (1)
