Previous in Forum: Rating of Power Saver   Next in Forum: LED Lights
17 comments
200 Amp Load
02/23/2011 1:45 PM
I am trying to build a 24Volt 200 Amp load
This is to test welder outputs, I feel the unit should be inductive as welding is inductive through the cables and welding wire.
I have designed a prototype using a standard bridge circuit and several transformers and standard analogue components to keep the current at a set set value, but as of yet it has not got of the design board as not too sure if I should use a single transformer / multiple transformers or multiple loads on a single transformer so they theoretically cancel themselves out.
Any help please
To realy test the welder would need some sort of programmable current device which will be the next step
7
Re: 200 Amp load
02/23/2011 2:25 PM
Sounds like engineering overkill from someone who does not know much about welding in general to me.
The load banks that the welding service shops and the companies who build welders are all based on simple wire element resistors and not much else.
I worked for a business as a certified welder repair tech and I used our load bank all the time. Inside it was just a bunch of big heating elements and a fan plus the pair of digital meters to read the amps and volts. I also have my own load bank and that too is just a simple resistance based load. When you are testing welders you are looking for voltage regulation and current capacity for a specific period of time or setting and thats it.
Re: 200 Amp load
02/23/2011 3:06 PM
There must be something in the air. This is the fifth or sixth GA I have voted today.
But it is easy to do so when a response is spot on. Well done.
Re: 200 Amp load
02/23/2011 4:26 PM
Thanks! I am just doing my part to combat the ever increasing forces of ignorance and unnecessary/pointless over engineering that tends to go with it.
Good Answers: 53
Re: 200 Amp load
02/24/2011 9:23 AM
Right, rheostat bank with cooling arrangement do the job,
Re: 200 Amp Load
02/23/2011 2:44 PM
Inductive?? Are the cables and wires formed into current-carrying coils?
Re: 200 Amp Load
02/23/2011 7:04 PM
While tcmtech's reply was spot on, in that you don't need much more than some sort of resistance for the load, be aware that 200A @ 24V is not far off 5kW, so there'll be lots of heat.
Way back, I built a load for testing a PSU in that power range using elements from radiant electric heaters. When it was near the top end of power x time (and things started smoking), we put it in a big bucket of water, and left it with cold water flowing in, and an overflow to the drain.
Provided the output's isolated from the mains supply (and it'd be a deadly welder if it wasn't), water's no problem, and very good for getting rid of unwanted heat.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: 200 Amp Load
02/23/2011 7:52 PM
load bank or sea water
One system
Re: 200 Amp Load
02/24/2011 1:39 AM
KISS principle. Load banks with resistors or individually switched lamps. Volt and Ammeter. Cooling. Thats it.
Re: 200 Amp Load
02/24/2011 6:04 AM
You don't need to make anything inductive, just use the original cables of the welder, which will test them as well, just as in actual welding......in fact making something inductive may cause you problems. All the inductance in a welder, IS IN THE WELDER!!!
I would find a source of say 110 volt heater bars, say 1 Kw each (more would be better say 10KW bars!). Each one will about 12.1 ohms. To get 0.12 Ohms (for 200 amps), you need 100 of these in parallel......or 10 of the 10 KW bars!!) Put them in clean fresh water to keep them cool. Distilled would be even better.
I would not use bulbs as they changer their resistance depending upon how hot they get, which depends on the voltage/current etc...
A simpler/cheaper way might be to take two thick disks of metal and solder thick copper wire between the disks till you get the right resistance, keep under water when using.....t6hats the cheapo method.....
Never done this before though, but thats approximately the way to go.....I hope I remembered my Ohm's law correctly!!!
Assuming the 1Kwatts bars=
Watts divided by voltage = amps. 1000watt element/110 volts = 9.09 Amps
Volts divided by Amps = Ohms. 110/9.09 = 12.1 Ohms.
Resistance = Volts/Current. 24/200 = 0.12 Ohms
100 1Kwatts bars in parallel = 0.12 Ohms.
Good Answers: 110
Re: 200 Amp Load
02/24/2011 12:18 PM
Buy a few water heaters, tanks and all.
Think big. Drive small.
Re: 200 Amp Load
02/24/2011 2:36 PM
The more practical rout is to simply make your own banks of resistor elements by buying the right amount of properly sized Nichrome wire online. Its cheap and designed to do what it does best which is turn electricity into heat.
Add a pair of digital amp and volt meters, some good adequately rated switches and a good fan and you have yourself a reliable adjustable load bank system.
Re: 200 Amp Load
02/25/2011 2:20 AM
solenteng; we built a 250 amp load bank using 1/2" dia. carbon rods 12" long with 5 100a aircraft toggle switches for a 200 amp D.C. welder with no load voltage 75 volts in a portable 24x24 x36 package with metering, with the idea of over loading 25%, with the 5th switch,this was air cooled. perry
Re: 200 Amp Load
03/22/2011 6:29 PM
Many thanks for all the realy helpful reposponces.
I noted your comments about being overkill.
I was using inductances as I wanted a small mobile unit which was both portable and did not generate huge amounts of heat, and would provide accuracy of +/- 5 A.
My original design was indeed a huge resistor bank with fans, but I needed a very small bench unit, also I could not dynamically load the units as the welder design incorporated a pulsed design which reacted to short, open, pinch mode etc.
The load resisitor method is great for static load but I could dynamic test the different modes of a weld, this includes simulating a short and then specific current steps which are controlled by a CPU.
Are there any ways of using resisitors to provide dynamic loads as ultimately they are only wire wound and so are inductive by nature when operating in the KHZ range.
Thanks for the great help and nay further information.
Re: 200 Amp Load
03/22/2011 7:06 PM
Forget about trying to use an inductive load. If you really want to simulate the cable inductance, the cables between the welder and the load will do just as well as in a welding operation.
" ...and did not generate huge amounts of heat...": facts is facts: power = volts x amps. You have to get rid of nearly 5kW, without melting a hole in the bench.
For your ±5A accuracy, it will be a lot easier and cheaper to use a calibrated ammeter, and switch the load (to give approximate values) rather than try to control the load accurately. Alternatives will be very expensive.
Re: 200 Amp Load
03/22/2011 8:10 PM
Thanks very much for the information really appreciated.
I was using inductances, as using the standard Ohms law of 2 volts across the load circuit at 300 A is only 600 Watts as the volatge delay is used to accuratly produce the load current level of 300 A with only 2 to 3 volts drop across the whole load circuit thats a load smaller than 5KW.
I used a similar device for 100 A loads @ 24V by using mosfets, as this produced a small and vey compact device witout the heat. 3 Volts @ 100 A using only 300 Watts, this was mainly due to the cabling between the devices and line.
Although this did have other effects such as phase lag etc, which i could have corrected with PFC circuit.
Many thanks will build the switched resistor version to do the inital testing ,as the experiences indicate great forum for info thanks
Re: 200 Amp Load
03/22/2011 8:34 PM
In your original post, you specified 24V @ 200A. This seems to have morphed into 2V @ 300A.
Also, 24V @ 100A may have been the rating of your similar device, but if you had actually used those values (rather than the 3V @ 100A) you would have had 2.4kW of heating to deal with.
Please clarify.
Re: 200 Amp Load
03/24/2011 7:36 PM
john DG thanks for the note
I will try to clarify
The mosfet load is designed for 3V@100A 2V@300A to reduce the energy disipation in the devices, dissipating max 600 Watts not KW.
The inductor was designed to provide the load on the 24V@200A MIG welder and a control circuit used to control the mosfets and inductors current phase lag ( < 90degrees) to control the current loading.
The load was designed to provide a synthesis of the filler wire as this is inductive, as I found out there were 7 stages of this ( lincoln welder design).
This enabled a reasonable synthesis of the filler wire process and enabled the welder to produce high power pulses although for only a short time, also the facility to simulate a reallife weld in PS spice simulation before building either units.
The result should produce a design concept to produce relatively high pulses of current, without needing high amounts of energy as the power is only required while the wire is shorted and pools on the material which is only a few mS per droplet.
There were several other factors such as reonance of the load with the cables, finding the true power delivered to the load under pulsed condition rather than DC, resitors were fine for the low frequency Tranformered designs but modern designs use different techniques to squeeze as much of of the systems with the least energy and high frequency pulses.
Thanks for the advice and pointing out my lack of explanation and understanding.
Register to Reply 17 comments
Andy Germany (1); Anonymous Poster (2); Doorman (1); JohnDG (3); K_Fry (1); loadshare (1); rakesh_semwal (1); solenteng (3); tcmtech (3); Tornado (1)
