Previous in Forum: Water Pipe Pitting   Next in Forum: Shells Under Pressure
12 comments
Wind Load on Glass
02/24/2011 4:52 PM
I am working on a project outside of Cairo and we are incorporating large, glass walls and sliding glass doors.
How do I determine the wind load on the glass. The door manufactureres have to have the infomation to verify the size of the units that are possible.
The buildings are only one to three stories in height.....
Thank you......Gary Stluka AIA
Re: Gary Stluka Architect
02/24/2011 5:04 PM
Engage the consultation of a knowledgeable person. Provide actual dimensions, not "the buildings are one to three stories in height."
--Tornado
02/24/2011 5:25 PM
To the comment from Tornado in #1 "Engage the consultation of a knowledgeable person" , I would add:
Engage the consultation of a knowledgeable person who is an engineer licensed in Egypt and insured in Egypt.
What value can the advice of anonymous strangers on the internet have when weighed against a properly considered solution from the person Tornado speaks of?
02/24/2011 8:02 PM
Excellent point. Lets not forget, Egypt with its combination of desert sands, Mediterranean moisture and I'm certain aspects that I cannot possibly dream of will have its own special collection of factors to know about wind loads and erosion on glass.
02/24/2011 5:30 PM
Another option is to carry out wind tunnel tests on models of the buildings, then scale-up the results both dimensionally and fluid properties to establish the load on the real thing. There are firms that can do this sort of thing for a fee.
Re: Wind Load on Glass
02/24/2011 5:56 PM
Gary,
Did you do the Planet Hollywood stuff?
02/24/2011 8:20 PM
What gets me is how an architect would not already have some idea about this.
But maybe he is a product of a kastrupsky talent surch....
Good Answers: 110
02/25/2011 12:06 AM
Truly a legend in his own mind.
I cannot tell you how tempted I am in these cases to write: "30 lbs. Tell them 30 lbs."
Think big. Drive small.
Good Answers: 11
02/25/2011 8:39 AM
Consult the local weather station, they have pile data for the dominant and strong winds on the area including the frequency of and wind speed of typhoons/hurricane on the area.
The strongest wind(speed) multiplied by a safety factor (say 2.5) for that speed would be the thing your glass manufacturer require.
Or given that designed wind speed, you could solve for the bearing stress between the glass and the frame-your maximum load should be computed there.
Give me money, ill show the equations, haha. joke only.
02/25/2011 8:41 AM
Glass is non structure materials and has lower density than its counterpart call glass ceramics.
Glass installation is effected by wind quality because of erosion and burst strength under pressure.
If your area get sand storm then you have to consider that in part of equation to calculate the glass thickness along with glass hardness.
If you have info of wind speed sand storm quality then you will be able to predict glass thickness if you know glass hardness.
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
02/25/2011 8:45 AM
If you are not qualified to make the calculations, then you MUST find someone who is. I am not trying to be facetious, honestly. There are many, many things to consider beyond wind load.
Here is a simple go-by to get you in the ball park:
FD=½ρv2CDA
FD is the force of drag, which is by definition the force component in the direction of the flow velocity
ρ is the mass density of the fluid
v is the velocity of the object relative to the fluid
CD is the drag coefficient — a dimensionless constant, e.g. 0.25 to 0.45 for a car
A is the reference area
This will give you normal wind loads. However, your glass is just as likely to be pulled out by pressure drop induced by wind shear.
Give the door manufacturers the nominal and maximum recorded wind speed for your area. That should be a start.
-A-
question everything
02/25/2011 9:24 AM
In the US we consult ASCE Minimum Design Loads for Buildings and Other Structures this document contains windseed maps to be used as a basis of design.Once a windspeed has been determined for the location we use the following to convert windspeed into a pound per square foot load.
windspeed squared x .00256 = psf
Once the psf is determned it is multiplied times 1.5 for structural loading.
This is a much abreviated method used here to plug numbers into ASTM E 13000 which is a methodology of determing glass failure.We are supposed to maintain a probability of breakage less than 8 per 1000.
You should consult an expert in your area because your codes or design practices are probably much different than ours.Many areas have specail wind conditions and the geometry of the building angle of installation and elevation of the glazing all factor into the proper design.
This is not the type of calculations used to certify code compliance however it is what the door manufacturers are asking for in order to determne a probable configuration to withstand loading.
It might not be a bad idea to ask this gentleman
Abdel Halim Galala Guru
Join Date: Feb 2007 Location: Cairo, Egypt Posts: 1557 Good Answers: 185
Re: Basic Wind Speed in Saudi Arabia 10/06/2008 1:10 AM
My dear
Junos2008,
In the following CR4 Thread Calculating Wind Resistance, you will find more data and details in calculating the wind load as per code ANSI/ASCE 7-88 & ANSI A58.1-82. For wind speed in Saudi Arabia, I prefer to use the worst case which reaches about 160 km/hr.
It is better to be defeated on principles, than to win on lies
Good Answers: 29
02/25/2011 12:46 PM
The blockhouse type Navy housing I lived in on Guam years ago had windows that were said to withstand a 150 MPH coconut. So, as mentioned earlier in the thread, locale specifics are a must.
-A- (1); Anonymous Poster (2); Doorman (1); Glassman (1); K_Fry (1); lyn (1); Noudge79 (1); PWSlack (1); RDGRNR (1); redfred (1); Tornado (1)
You might be interested in: Interior Doors, Exterior Doors, Industrial Doors
