Previous in Forum: Loading of Transmission line   Next in Forum: Rotor Bar Squirrel Cage Motor
10 comments
shot circuit test
02/25/2011 1:57 AM
how can done a short circuit test in a mcb.
India - Member - New Member
Good Answers: 164
Re: shot circuit test
02/25/2011 2:05 AM
02/25/2011 2:30 AM
Show it a short circuit.
02/25/2011 5:19 AM
If it survives the experience, then it's like a cat: one life down and eight to go.....
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
02/25/2011 7:16 AM
Did you mean Schrodinger's cat experiment?
Good Answers: 116
02/25/2011 8:13 AM
Usually, one takes it to a certified test station or has a test station with approved personnel and test sources and instruments on the site. Since an mcb can break 10 kA or more at 415/240V such equipment is costly.
02/25/2011 12:05 PM
ooh not cheap as Eveready battery
Good Answers: 116
02/25/2011 1:13 PM
Hi, Hithuanand, I hope you are well!
190 amp hour gas turbine starter battery - about 2 kA short circuit. BIG battery or 300 kVA 415/240V transfo needed for mcb tests Would your arc furnace transfo do? With fee to Guest as "foreigner", as it was called when I was an apprentice?
02/25/2011 7:27 PM
Yeah i am fine...Thank you. Guest can connect more then seven MCBs at a time in arc furnace here. But i don't think the charge man will be happy with that.
Good Answers: 181
02/25/2011 7:54 PM
From my experience of furnaces would the charge man even notice the slight bang as a MCB exploded?
I've only worked on induction furnaces though.
02/25/2011 9:04 PM
Yes.... you are correct the sound level in Electric Arc Furnace is so high.It cause severe headaches also.
67model (2); hithuanand (4); kvsridhar (1); PWSlack (2); TonyS (1)
