Previous in Forum: Rotor Bar Squirrel Cage Motor   Next in Forum: autochangeover circuit for gensets
relay coordiation
02/25/2011 5:27 AM
what is mean relay coordiation
Re: relay coordiation
02/25/2011 6:06 AM
British Standard 7671.
Good Answers: 29
02/25/2011 8:11 AM
Good Answers: 116
02/25/2011 11:29 AM
  1. Coordination between relays used for protection usually refers to the desirable action that a fault is always disconnected by the device immediately upstream of the faulty load.
  2. Disconnection by a device closer to the supply, which will also disconnect other loads which are working normally is not desired.
  3. This requires (ideally) that the settings and operate time versus current curves of relays, [with allowance for tolerances from dial/plug settings and the behaviour of current transformers] are such that down-stream devices operate before up-stream devices for all possible fault locations.
  4. Sometimes, the "worst possible" fault at a downstream position can exceed the maximum breaking capacity of its local protection. In this case, upstream protection may be required to operate faster than local protection for currents exceeding local breaking capacity.
  5. Also, in case 4., the local protection device may be rated to carry, but not break the highest fault current for the operate time of its upstream protection [to ensure that it was still suitable for continued use after the fault]. In that case, the ratings are coordinated as well as the relay/in-built operate time.
02/26/2011 7:40 AM
I think it is great when people write and consolidate concepts - and sometimes get hammered for doing so - and when I do so I better understand the principle.
GA from me.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
Good Answers: 53
Re: relay coordination
02/25/2011 11:53 AM
There are two types of relay coordinations in general.
1 Operating two or more electric relays in a systematic manner to achieve certain objective.
2 Click here for type two of relay coordination.
Good Answers: 19
02/26/2011 12:47 AM
Ramesh,Freelance Electrical/automation Consultant
02/26/2011 11:08 AM
Next question from the OP will be "why doesn't the fan stop when I turn the bathroom light off".
Where in "what is mean relay coordiation" does fault level discrimination get a mention?
The OP hasn't given enough information (as usual)
Reply Score 1 for Off Topic
67model (1); Anonymous Poster (1); Coldspot (1); PWSlack (1); rakesh_semwal (1); ramvinod (1); RDGRNR (1)
