Previous in Forum: Autodesk Inventor Question   Next in Forum: Fatal Error? Autocad
13 comments
United Kingdom - Member - New Member Fans of Old Computers - ZX-81 - Dragon 32
Pemutations of Sudoku method anyone?
04/04/2007 4:29 AM
Hi,
Given that the digits 1 through to 9 can be re-arranged 362,880 different ways ( permutations ) or 9P9 how could you mutually exclude all the sub-sets of these where the 1st 3 digits are the same ( but in any order ), the 4th to 6th digits are the same ( but in any order ) such that the last three digits are different anyway by default.
What i am basically after doing ( programatically ) is checking the possible total solutions for Sudoku so the 1st line could be>>
123456789
but the 2nd line can't have 1, 2 or 3 in the 1st 3 characters,
can't also have 4, 5 or 6 in characters 4 to 6 and for the last 3 can't have
7, 8 or 9
Repeat as per Sudoku rules down to the last or 9th line.
As a side tought i've wondered if nought could be used in a 9 by 9 grid, how many solutions there now are?
I've thought of bit-wise masking so i'm posting this in the programmers forum too.
In case you are curious 10P9 yields 3,628,880 ( ten times as many variations for the 1st line alone ).
I would be curious how to do this for any size of grid using say
0 to 9, A to Z and a to z as characters.
Regards,
Dr M.
Pathfinder Tags: Permutation permutations sudoku
Re: Pemutations of Sudoku method anyone?
04/04/2007 11:41 PM
IIRC the Sudoku site covered some, if not most, of this some time back. Mainly setting up all possible puzzles to foist off on an unsuspecting puzzle fanatics.
You can have your fun your way. I have my own ideas of fun.
Thank you just the same.
04/05/2007 1:26 AM
Sorry I just can't get into games with such a small set of possibilities. I prefer GO with something like 10^200 possible permutations. Beats the heck out of Sudoku and even Chess.
04/05/2007 10:24 AM
What is it with some of you guys? Why do you feel the need to to thrust yourselves up to a position of supposed superiority over fellow posters? Dr. Marten has laudably chosen to engage himself in a thoughtful analysis excercise. So what if someone's done it already, or it's not your idea of fun. Give the guy a break, or better yet, a hand. This is not place for mental flexing and posturing. Let's keep this a positive and constructive forum and leave your personal biases out of it.
04/05/2007 10:30 AM
Ooh! He told you! And you! And You, too!
04/05/2007 10:56 AM
"What is it with some of you guys? --- Let's keep this a positive and constructive forum and leave your personal biases out of it."
And YOU TWO are hiding under your desks aka 'Guests' name!
04/05/2007 2:43 PM
I don't think the good Doctor has been hurt by my polite comment expressing a preference. The comment was relevent in that it pointed out another game with a large number of permutations, if you even understand what that means. I did not pass judgement on his behavior as you now do on mine. If you really want to know what I think it is that generally speaking and more and more so GUESTS SUCK. Whether too lazy to sign up or too weak to not need to hide behind the anonymity of guest status or maybe even members who log on as guests I wish there were not such an option to do so. People like you abuse the status when you come in with your critical pot shots and from the safety of no identity you can be rude, as many of you are. You can kiss my rear as far as I'm concered.
04/08/2007 8:17 AM
I'm working on the next level of sudoku.
It uses hexadecimal 0 to F with a 4 by 4 layout...
Even I am having trouble doing it and I'm a sudoku maniac!!
John
04/09/2007 8:55 AM
Elektor magazine by any chance. Yes it's me again.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/09/2007 10:59 AM
Is Elektor magazine still going Brainwave??
The last issue I saw must have been in the 70s
John.
04/10/2007 5:47 PM
Very much so they run a competition using Hex for their Sudoku. It is now Elektor Electronics also available on the web.
04/09/2007 5:28 PM
Hi All,
Me again ( wiv me BIG boots on ).
Anyway, i am rarely hurt at all by comments in post threads, just to let you all know.
What if you had a 36 x 36 grid using the characters 0 to 9 and the letters A..Z and a..z? With 36 sub-grids of 6 X 6 character spaces. How many permutations then?
I am after the "thought" process you might use to come up with the total number or permutations really, for ANY size of Sudoku grid, as a PROGRAMMING exercise, no it's not homework!!
It is all down to curiosity really!!
I have created a small VB.Net program that iterates from 12456789 to 987654321 and spits out all the numbers where each digit is different.
It takes ages though, just to do that!! :-(
I'm off to try the same question on two programmers forums....
Regards,
Dr M.
(Stomping off in BIG 'bovver' boots....)
04/09/2007 5:44 PM
Hi ALL,
'Here is the code anyway ( that i mention in my previous post ).>>
Dim num(9) As Integer
Dim numString(9) As String
'Dim possNums(9000000) As Integer
Dim possString As String
'Dim sw As New StreamWriter("C:\myNumbers.txt")
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim count, index As Integer
For index = 123456789 To 987654321
If (uniNum(index) = True) Then
count += 1
'possNums(count) = index
TextBox1.AppendText(count.ToString & " " & index.ToString & vbCrLf)
'sw.WriteLine(count.ToString & " " & index.ToString & vbCrLf)
End If
If count Mod 50 = 0 Then TextBox1.Clear()
Next
'sw.Close()
MsgBox(count.ToString)
End Sub
'Test to see if number is like 123456789 or 987654321
'where each digit is different.
Private Function uniNum(ByVal num As Integer) As Boolean
Dim numS(9) As String
Dim str1 As String
Dim index1, index2, index3 As Integer
str1 = num.ToString
For index1 = 0 To 8
numS(index1) = str1.Substring(index1, 1)
Next
For index2 = 0 To 9
For index3 = 0 To 9
If index2 = index3 Then GoTo SkipTest
'See if the number 'num' contains a "0"
If numS(index2) = "0" Then Return False
'Compare each number in the number 'num' with itself.
If numS(index2) = numS(index3) Then Return False
SkipTest:
Next
Next
If index2 = 10 And index3 = 10 Then Return True
End Function
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
04/10/2007 2:52 AM
Whooo! I'll stick to the crosswords, thanks.
'The truth is out there' The lies are in your head.
Register to Reply 13 comments
Anonymous Poster (2); BrainWave (2); DrMarten (2); Electroman (2); PlbMak (1); rcapper (2); Stirling Stan (2)
You might be interested in: Line-shaft Spools, Power Line Network Components
