Previous in Forum: This is a Question to Administrators   Next in Forum: Female Engineers?
11 comments
Star Delta
02/25/2011 3:30 PM
how is it working.
Re: star delta
02/25/2011 4:00 PM
It works fine here. How well does star delta work for you?
Re: star delta
02/25/2011 4:31 PM
I'm not sure it works all that well for anyone, especially if open transition.
Good Answers: 97
Re: star delta
02/25/2011 4:42 PM
She used to work at the BadaBing, but someone greased to pole.....
CRTL-Z
Re: star delta
02/25/2011 4:57 PM
Sure you're not getting confused with the Delta of Venus? Venus is, after all, a planet, not a star.
Good Answers: 97
Re: star delta
02/25/2011 5:06 PM
Yes, Delta of Venus had the power to cloud men's minds..I am confused.
CRTL-Z
Good Answers: 53
Re: star delta
02/26/2011 12:55 AM
If Pluto can be pulled this side from the group why not push the Venus to that side, That will solve the star delta problem for ever.
Good Answers: 181
Re: star delta
02/25/2011 4:59 PM
Didn't know it was still working, should be like me and drawing a pension.
Re: star delta
02/25/2011 5:36 PM
Are you talking about a star delta motor starter, or a star delta winding on a transformer?
In the case of a star delta motor starter (I usually say (and hear) delta star), the basic purpose of any reduced voltage motor starter is to control the inrush current during startup. The delta star motor starter changes the voltage by changing the configuration of the (secondary) windings of a transformer which is part of the starter--in one configuration the windings are configured delta, in the other wye (or star), delta gives a lower voltage.
So the motor is started in the delta configuration, and switched to the wye after the motor is up to (or almost up to) speed.
Re: star delta
02/25/2011 5:48 PM
Sorry; that's backwards. The first step is star, followed by delta. It is the motor windings, rather than the transformer windings, that are switched.
(In theory, if there were only one motor on a transformer, it might be possible to switch the transformer instead. I've never heard of such a case, but who knows?)
Re: star delta
02/25/2011 8:28 PM
Thanks for the correction! Actually, although I've worked on a lot of motor starters, I can't recall ever having worked on a star delta starter.
Re: star delta
02/25/2011 8:43 PM
They don't seem to be all that popular in the US. I've seen a very few, and have built/operated some closed-transition auto-transformer starters that worked fine.
Register to Reply 11 comments
JohnDG (1); rakesh_semwal (1); redfred (1); rhkramer (2); TonyS (1); Tornado (3); Unredundant (2)
