Previous in Forum: BSMET to BSME Transfering Credits   Next in Forum: Bearing Load
16 comments
Clever Engine Design.
03/05/2011 9:47 PM
it is very clever engien disign, compact and efesiant, but where does it stand from the engineering point of view, can i get your coment on it. but just to be clear it is not my design i found it on youtube
guds777
Pathfinder Tags: engine design
Re: clever engine design.
03/05/2011 9:48 PM
http://www.youtube.com/watch?v=YzBgoDeY3Ws&NR=1
guds777
03/05/2011 9:51 PM
no cam and no valves.
guds777
03/05/2011 10:48 PM
Lots of pressure on one (or two opposed) sliding/rolling elements. It might fare better in translation, though. The video is more clever than the design, I suspect.
03/05/2011 11:22 PM
but ,,if,, enuff lubrication then it should not be that much of an problem. And if maybe he integrate a ball in the sliding part then he can reduce some of the friction.
guds777
03/07/2011 1:02 AM
I am working on similar concept for many years. These sighted problems and experienced problems are being worked out. For an individual, it is rough road into a tunnel with no light across.
03/06/2011 12:13 AM
Built a rotary engine/pump many years ago, where the action was different from the youtube one, but the action on the pistion rings was the same, the piston rings due to friction where forced to rotated in the groove, the result was that they eventual broke.
Regards JD.
03/06/2011 1:54 AM
And here is a another design who are very interesting.
guds777
03/06/2011 1:55 AM
http://www.pattakon.com/pattakonFly.htm
guds777
03/06/2011 2:15 AM
The animation has the left rotor passing alternately over/under the right rotor. This is not credible. Cartoon goofs like this do not speak well for the ideas supposedly being shown.
Good Answers: 213
Re: Clever Engine Design.
03/06/2011 10:33 PM
One is very, very unlikely to find a viable motor design on Youtube...
03/06/2011 11:36 PM
but it is fun to discuss difference in different motor design, what will work and what will not. Sometime one can deliver the piece in the puzzle another was missing.
guds777
03/06/2011 11:41 PM
and i like to listen on what the engineerings are thinking so i can learn. Don''t We All.
guds777
Good Answers: 196
03/07/2011 1:35 AM
The stationary pin in the slot and the the pin/slot "crosshead" do not suggest an ability to form hydrodynamic or squeeze type fluid films approaching the load carrying capability found in most common piston engine mechanisms. This suggests that power output per unit weight of the mechanism will remain uncompetitive until improved bearing and material technologies are discovered.
An engine design waiting for basic materials research in order to be successful does not look very promising. But I hasten to add that my comments are based on current engine technology in the range of 5 to 5000 kw. There may be some promise for this design in smaller engines used for small remote control vehicle applications as well as lightweight portable power sources where the realtionship of mass to surface area has a different effect.
Ed Weldon
03/07/2011 2:43 AM
It appears to be a two stroke engine made more complicated with more wear points.
03/07/2011 9:16 AM
Same here.... basically a piston port 2 stroke, that doesn't use a crankshaft. I would have to wonder about the wear on the piston/pin slot.
Live Slow - Sail Fast
03/07/2011 1:02 PM
I think that vibration may be a problem and somehow the designer must stop the "join" of the rings ever going over the inlet or outlet ports......
The peg in the side of the piston must be fitteded with a roller bearing.
Also not much room for axial thrust bearings for the shaft and as the whole ai´rcraft(?) will be pulled along by this shaft........
I am sceptical.
Register to Reply 16 comments
Andy Germany (1); CaptnPea (1); cwarner7_11 (1); Ed Weldon (1); guds777 (7); jdretired (1); Tornado (2); WAWAUS (1); yesyen (1)
