Previous in Forum: pump   Next in Forum: Valve
8 comments
India - Member - New Member
Pump
03/08/2011 9:07 AM
what are the possible reasons for centrifugal pump to get trip ?
When Emotions runs high ,Intellectual wont work
Re: Pump
03/08/2011 11:57 AM
One possibility is that it is being asked to do too much work.
Another is that it has a motor internal fault.
Re: Pump
03/11/2011 4:22 PM
its due to overload, is it with gland or mechanical seal. also check for the sound is it making any noise.
Good Answers: 181
Re: Pump
03/08/2011 4:54 PM
Over work is the most obvious reason. Followed by mechanical failure of either the pump or motor.
Good Answers: 97
Re: Pump
03/09/2011 12:59 AM
Check and monitor your power supply.
OT - I don't think drugs can put a pump on a trip.
Good Answers: 21
Re: Pump
03/09/2011 3:25 AM
Impeller can get clogged then the motor will draw too much current and trip your MCB or whatever.
Good Answers: 130
Re: Pump
03/09/2011 6:13 AM
Only if it jambs the impeller.
A internally clogged impeller delivers less mass flow = takes less HP.
Hence, over revving can kill IC pump engines.
Basically an electrically driven centrifugal pump must have some physical obstruction/extra drag, preventing/limiting impeller rotation, to kill its motor.
A induction of mud could do it. As would seized bearings. As would a failed shaft seal resulting in a motor full of water. As would a rock, or stick, or tangle of string, between casing and impeller.
Mind you, motors have to be correctly sized to the pump and appropriate quality.
Good Answers: 21
Re: Pump
03/18/2011 9:12 AM
Yes I did mean the impeller shaft rather than the impeller itself (or the space between multi stage impellers getting clogged).
In my experience with centrifugal pumps pumping sea water, when the impeller gets internally clogged (if its a closed impeller), then the same material usually causes problems around the seal/shaft area causing increased resistance to turn the impeller=more current drawn by the motor=MCB's tripping.
I thought it more appropriate to give a short answer with limited detail as the question was rather open.
Good Answers: 137
Re: Pump
03/09/2011 6:08 AM
Because it's been working hard for a long time and its owner thinks it deserves a treat
Register to Reply 8 comments
34point5 (1); Codemaster (1); Fezi (1); Hendrik (1); MACA (2); PWSlack (1); TonyS (1)
