Previous in Forum: Condenser of 330 mw   Next in Forum: Laser Welding of Stainless Steel
External Pressure Controlled Valve.
03/08/2011 11:35 PM
I'm in the process of designing a rebreather for diving and I've run into a snag. I need to regulate the pressure in the "breathing bag" in conjunction with the increase/decrease in pressure on the outside of the "bag". The way I understand it a standard release valve is set by compressing a spring to supply the resistance for the valve. Do you get a commercial valve that could be adjusted by an external source? I know dive regulators have this function but I'd really not have to reinvent the wheel if I can get one off the shelf. I'll be looking at keeping the internal pressure of the "bag" at about 0.1 bar higher then the out side pressure.
Pathfinder Tags: diving rebreather valves
Re: External pressure controlled valve.
03/08/2011 11:56 PM
You might try searching on "differential pressure regulators". The ones I sometimes use in refrigeration wouldn't be sensitive enough, but the idea is that upstream pressure is on one side of the diaphragm, and downstream on the other. This effectively subtracts; hence differential.
03/09/2011 5:04 PM
Thanks, this looks like just the thing I'm looking for. I had a quick look around and the valves look larger then I'd like but I'll try the local supplies and see what they can get for me. Thanks again
Register to Reply 2 comments
