We have a problem with the voltage from a WEG GTA250MI33 / John Deere genset. The load on this machine is made up of a few large electric motors with a combined total power of 138kW. These motors are controlled by a PLC. When the power demand from these motors is below 90kW the genset supplies 230V between any of the three phases and Neutral. This voltage remains tha same even with no load on the machine.
The problem is that when the load is increased, the voltage also rises. The maximum voltage rise was measured at 262.5V. We measured the power factor on this genset and it was 0.52. The fequency from the genset is quite stable at 50Hz and the engine sounds very smooth as it is loaded and unloaded.
We suspect that the problem might be on the AVR, but we have no information about the AVR fitted to this genset. Can anyone maybe tell us where to start looking?
