Previous in Forum: Energy Transfer Station (ETS)   Next in Forum: Welding Applicable/Recommended For Sizes of Pipe
20 comments
Equipment to Liquefy Natural Gas
03/09/2011 10:30 AM
I want to take the natural gas from my home and use it in another place. Anybody knows any equipment can do it. If not, I am thinking of the principle of scuba tank, to compress natural gas into a container. Is it easy to do it at home? Any specialist supplier in this area? Thanks a lot!
Re: Equipment to liquefy natural gas
03/09/2011 10:40 AM
Good Answers: 53
03/09/2011 10:41 AM
Is gas used at home is subsidised by govt?
03/09/2011 10:45 AM
It cant be done.
Your domestic natural gas supply is fluffed up with air which make it impossible to compress it to the point of condensing using any practical means that the average home owner could work with.
Good Answers: 61
03/09/2011 11:24 AM
Did you try to Google "Equipment to liquefy natural gas"?
Do it once and do it right
03/09/2011 11:32 AM
There are some Asian buses that carry NG in elastomer bladders on top. CNG (compressed NG) would be simpler than LNG (liquefied NG). I don't know if any air that may be in it would present any special problems.
03/09/2011 11:47 AM
The problem between natural gas in vapor form Vs liquid form is that the liquid form has around 600 time greater energy density than the vapor form does.
Those Asian busses cant go very far without having to be re fueled. What I understand is that their effective range is is only several miles at most at highway speeds.
03/09/2011 12:08 PM
Not necessarily in liquefied state! My purpose is to heat up a greenhouse where no natural gas supply in my garden.
03/09/2011 12:12 PM
My purpose is to heat up my greenhouse in my garden. Natural gas in compressed state is still OK. Anyone has used such equipment?
03/09/2011 1:43 PM
To get the pressure that would liquify, you would need to get a compressor. For one rated for NG, you would have to fork over some bucks. Do a Google search on small gas compressor. I found a 10HP reciprocating one for ~$19,000. I'm sure there are smaller ones. Search around and see what you can find.
All in all, I think your best bet would be to get a container and refill it with as needed at a filling station.
03/09/2011 1:52 PM
Is a small air compressor is OK for natural gas (also consider the risk of explosion)? Anyone has tried it before?
03/09/2011 2:05 PM
"Is a small air compressor is OK for natural gas (also consider the risk of explosion)? Anyone has tried it before?"
No, don't do that. At best you will have compressed nat gas, not LNG. At worst, maybe a big Ka-boom!
Why not propane? Products of combusting propane are CO2, water and heat. Your plants need these anyway, and propane is readily available in many storage forms.
Re: Equipment to Liquefy Natural Gas
03/09/2011 3:02 PM
Hire a plumber. Have him put a tee in the supply line and run it out to the garden.
DO NOT TRY TO COMPRESS THE GAS YOURSELF. You could wind up permanently dead, forever!
Good Answers: 181
03/09/2011 3:51 PM
Eeerr isn't dead usually permanent?
03/09/2011 4:07 PM
Just trying to make a point. I forgot that I wasn't talking to joe.fordham, the savior of humanity.
Good Answers: 11
03/09/2011 11:07 PM
cheerz to that man, it's always funny to think recalling that guy.
03/09/2011 9:44 PM
There are CNG compressors available in home sizes; some prices I saw were around US$ 4000-6000; using explosion-proof electrical design. The best scheme seems to be adsorption-type cylinders at 500 psi. They resemble SCUBA tanks, but not as heavy, because of the less pressure. This appears to be a mature technology, suggesting that the safety issues have been resolved.
Air compressors would not work.
Running a branch pipe would surely be cheaper, unless your garden is remote from the house.
03/09/2011 10:03 PM
What search words did you use to find these? I'm having a hard time thinking of the purpose of these in a small-scale situation, as in; "What would be the source of the NG, and the reason for compressing it in cylinders." Maybe for insurance if you had an intermittent utility supply?
To Editor Crankshaft:
"because of the lower pressure." Would be better.
03/09/2011 10:15 PM
Quibble, quibble; but I don't object to the change!
My second search was on "cng compressors"; I was surprised at the number of hits.
Good Answers: 181
03/09/2011 10:33 PM
Were do you live?
I just want make sure I'm a long way from you!
03/09/2011 11:03 PM
You might want to look around a little more. In some areas of the world, CNG is a fuel of choice, complete with an infrastructure of filling stations, etc. I understand the safety record compares well with gasoline/petrol, one reason being that leaks dissipate upward rather than pooling on the ground. Simple vehicle conversion kits are also available.
If it's CNG (rather than LNG), BLEVEs are irrelevant.
(Nuke phobia redux?)
Register to Reply 20 comments
Doorman (1); lyn (2); Mikerho (2); Noudge79 (1); PennPiper (1); rakesh_semwal (1); tcmtech (2); TonyS (2); Tornado (5); youngken (3)
