Previous in Forum: "Planet Earth" TV Series is Very Cool   Next in Forum: One Week in Each Country Makes a Good Mobile Engineer
Nickel Vapor Deposition (NVD)
04/06/2007 3:05 AM
Hello
Looking for specifics to build a NVD plant. there is lots of info available on the web
but it all seems very general. Any clues would be helpfull.Looking to make nickel shell molds.
Good Answers: 109
Re: Nickel Vapor Deposition (NVD)
04/07/2007 2:34 PM
Hi,
evaporation, sputtering. ionbeamdeposition and similar - all are costly as vacuum equipment is expensive in investment, operation and maintenance.
Depending on your application you may have more economic opportunities.
So to give a sound answer send some more details.
Happy holidays
RHABE
04/07/2007 6:38 PM
Thanks Rhabe
application is for molds from 3mm to 10mm thick up to 1 meter wide
Have tried electro forming with some success. but time required and chance of failing is high
But am all excited about NVD
I understand these things arnt cheap
Good Answers: 109
04/10/2007 3:08 AM
Hi,
vacuum metal deposition is used with maximum thickness of 10µm so if you start with a vacuum process you need a second process to reach the desired thickness.
The maximum thickness used from vacuum deposition is dictated by cost considerations.
If thickening is done after vacuum coating (for example the nickel contact pads on semiconductor electrically conducting aluminum structures) this is done by electroless plating with pure Ni (soft) or NiP (high strength) but both with lilited thickness to near 100µm.
If thicker is necessary then a traditional galvanic process or a plastic coating or sometimes casting concrete or similar material to the back of the metal structure.
To have a look at used coating equipment look at lasermotion.com
a process for electroless nickel is sold by shipley (manufacturer of semiconductor processes)
thick nickel coating can be done by any galvanic shop.
Have success
RHABE
04/09/2007 6:04 PM
Is electro-chemical deposition viable here?
04/10/2007 4:05 AM
Speak to Teer Coatings Ltd (UK) who specialise in this type of equipment.
Anonymous Poster (2); mewebe (1); RHABE (2)
