Previous in Forum: Regarding motors   Next in Forum: Energy Audit of Hotels
About Rectifier
03/18/2011 2:28 AM
Dear sir, i made one rectifier bridge (IN4007 diodes) and connect parallel one resistor(10K)and capacitor (470uf) and then measured rectifier bridge out put by giving input 0 to 15 VAC to bridge i got DC voltage according to formula (Vdc=0.90063*Vrms) up to 8VAC after that i didnt get correct output values[voltage increased after 8VAC].why it is so?please tell me. is there any good method to get correct values?please tell me sir thanking you
Re: About Rectifier
03/18/2011 10:45 PM
With a light load the correct peak voltage is VAC RMS * 1.414214 (the square root of 2). Not sure where you got 0.90063.
Good Answers: 120
Re: About Rectifier
03/18/2011 11:17 PM
what rcapper says is correct, however, you have a slight load to discharge the capacitor, and so the cap willnot charge to the RMS peak of 15 volts (21.2 volts), instead it will charge tothe peak minus two diode forward voltage drops of 0.7 volts each = 1.4 V. thus at 15 volts and just the 10K load you will see 21.2 - 1.4 = 19.8 Volts.
As you ramp down to zero, the same relationship will follow, except when your AC drive drops below a peak voltage of 1.4 volts, when none will pass.
Per Ardua Ad Astra
Re: About Rectifier
03/19/2011 1:56 AM
Output DC might still contain some ripple and therefore DC output if measured in DC range will not give exact DC value.Try measuring using True r.m.s. multimeter.
Register to Reply 3 comments
ashoktoshniwal (1); aurizon (1); rcapper (1)
